My Setup :Doppler Vortex 50cc Performance Kit £174
Doppler WR7 Exhaust Kit £174
Polini 19.5 Chrome Carb £115
Polini Race Clutch Kit £54
NGK BR10EIX Spark £10
Polini Air Filter Sheet £11
Doppler Grips £15
Extra Parts:
Road Angle Professional Connected £300
Garmin Sat-Nav (bike) £89.99
Cyclone C-11 Bike Alarm System £23.99
Aprilia RS50 1999
Doppler Grips £15
Extra Parts:
Aprilia RS50 1999
i see ALOT with bbk, quiete common really
that is a expensive kit though but with it having a powervalve im sure itl pull like hell when it opens so thats what id go for personally if money wasnt a issue
if i cudnt get that one then pink top performance 75cc top end for sure
Engine Always Screaming!
thats fair enough :P i know but wouldnt it just be the dogs bollocks!! by the way im 16, but am rolling the money in, might think about this in the future because the rs is just beast!!mine killed off all 4stroke 125's acceleration and top end
even raced a rs125 but he killed me :L wernt far off through 1st, 2nd & 3rd but then he stopped toying :L (it was fairly fucked i mean bigtime! but still hit 90 :O)
what do you think off mine?comments please!!
Here is some reviews:
Some are 80cc kits, some 480cc some 290cc exec.
Application '05 Yamaha WR 250F w/pro-motto-billet quiet insert in stock exhaust. My goal was to give me more power for the sand and straight sections in Desert racing. Result more grunt down low and big improvement riding a gear high through whoops. Overall my top speed seemed to suffer. Conclusion: For Desert Racing not worth the money, for Woods riding totally worth it. Installation excellent. Durability incredible! Installed 03/2007 prior to a 10-race Desert Series. 2008/09 and 2010 averaged 60 hours/year ride time and competed in 3 additional Desert races. Today 11/2010 original Athena piston going strong.
do not buy this kit for the YZ125 unless you are ready to split the case and do some grinding and do not buy the kit unless you can get the new 1 part head . the older 2 part head will give you nothing but blown head gasket after blown head gasket
TECH NOTE: THIS KIT DOES REQUIRE SOME BORING OF THE ENGINE CASES FOR PROPER CLEARANCE BETWEEN THE CASES AND THE OVERSIZED PISTON.
I installed this big-bore kit on my 2006 YZ250F with no other modifications whatsoever....no jetting, cams, pipe, timing or NOTHIN'! It bolted right on, everything fit perfectly, and the improvement in power is much better than any pipe could give! Don't waste your money on a pipe! Buy this!
With the Athena kit it's a whole 'nother bike! Roll on the power in 3rd and lift the front wheel. Power is smooth and she pulls right up to the rev limiter. Install was easy. Ceramic coated piston, quality gaskets. Excellent Product!
Every thing you need to bolt this on comes in the kit.I had no problems at all the gaskets held up for 20 hrs of race time with no problem!Great low end and mid gain.The engine still revs out nice but not as fast but it hits hard taking off.Make shure you have a heavy-duty clutch kit.Nice way to run from other ltr's or the big bore quads!
I bought a 478 Athena kit for my YFZ 450 last year around January put in about 30 hours of riding time and 3 oil changes, did perty good for a while but this last time I went to Glamis the piston Craked right down the middle so now I will be upgrading to a stroker kit.
This is a great kit. Easy installation and great instructions. Had no previous engine repair experience and it only took me a couple hrs but saved me hundreds of dollars! The price alone was better than any others! I have not hade any problems. I use the bike for track riding and trail riding. I noticed more torque and speed on the first lap!
Doppler Grips £15
Extra Parts:
Aprilia RS50 1999
Top Performances Aluminium 50mm kit
Top Performances Reinforced Race crank
Top Performances "Nardo" exhaust system
Top Performances Red CDI kit
Top Performances 6th gear
Top Performances Race Clutch kit
Top Performances 8 valve reedcage
Top Performances Ergal Gearselector-roller
Mikuni TM24 Flatslide Carb
Custom TM24 Throttle cable
High Cap Oilpump
24mm Manifold
Custom TM24 Airbox adaptor
Custom Airbox Mod
15/47 gearing
and other not engine ralated mods/upgrades![]()
shal we all chip in to a forum bike with a list of these mods?haha
Doppler Grips £15
Extra Parts:
Aprilia RS50 1999
Ok i'd spill a few hundred thousand into athena's fuel injection system for the am6 engine. with all the fancy electronics to ensure optimum performance. on top of that i'd have all the usual performance mods.
Back on to off roading, 80cc is enough for most Sunday riders, unless you have motocross experience 80cc is plenty. Going on a green laning trip in august with my Furia (am6) so will get a vid up then.
Malossi MHR team 80 or Hebo manston 70 363 euros
Malossi Gp MHR or Custom made exhaust 299 euros
Malossi RHQ crank 285 euros
PWK 28 or TM24 169 euros
tp 8 valve reed cage 79 euros
Programmable hpi digital ignition 470 euros
Stage 6 clutch plates and modify 50 euros
clutch basket for 5 plates
Plus full tuning of the cillinder and flowing of the crankcases around 150 euros
Total 1865 euros
EJD : if i was you i wouldnt look into 50cc bikes, look for 125's for next year! 50's are okay and can be alot of fun, but in reality its much better to get a 125 and be done with it! 50cc and off road isnt a fun mix! Soon get bored.
I guess a 125 would be more worth while and also a bigger choice![]()
Doppler Grips £15
Extra Parts:
Aprilia RS50 1999
2 stroke 125 off road, insane fun just pure power!!!! yz 125
mates got a ktm 125 for the road (2011)
he bought a 154cc bore kit for it, had it bored out to 200cc
race exhaust
race clutch
race crank
orange rear sprocket - like 210 tooth or something its huge
lightend flywheel
upgraded reeds and 34mm carb
its a bloody WHEELY MACHINE for the road and off road, its just a BEAST and drips a little oil from running a bit rich during run in period even thouggh he SCREAMS it![]()
i saw a video once with a rs with that athena power vavle kit fitted my fucking god it looked crazy!!! looked like you were watching the rs 125 tbh
Aprilia rs 50 2000
Top performance Pink 75cc
Doppler Endurance crankshaft
Arrow racing exhaust with carbon endcan
Dellorto 21mm carb(92 main jet)
Stock air box modded
Top performance Cdi
Malossi reed block 0.30mm
Conti race clutch kit
14/47 Gearing
Mono rear
Michelin pilot sport tyres
Rs 125 front master cyilinder
Malossi upgraded clutch springs
Rs 125 Headlight
UPGRADES to come
24mm mikuni flatside carb
Double bubble screen
Yasuni R3 exhaust
Gear indicator
Custom rearsets
Full respray and frame polish
Doppler air rear shock
