Hi,
Just got an Aprilia RX50 2006 (am6 engine), it has been sat for a while with the previous owner. It had a new piston, rings and cylinder head just before I got it.
However the speed is very slow and there seems to be problems in the gears .
I can pull away in first gear, but the revs go stupidly high. When I work through the other gears, after about half throttle it does nothing and provides no power. I couldn't even get to 25mph. It sort of 'splutters'.
I've been told this may be because it needs new crank seals, is this the case?
Any help appreciated, many thanks.
Engine Always Screaming!
