Results 1 to 5 of 5
Thread: Differing front brake pad thickness, how to arrange when putting back?
    apriliaforum expert jmardy's Avatar
    Jun 2011
    San Rafael, California
    I removed my pads to clean up my calipers and didn't keep track of what pad came from where.
    I measured them and they vary in thickness by .20 mm or so.
    Does it matter where they go back in? I.e. should the fatter ones go on the inside or vice versa, or am I just thinking too much?
    Marin County, California
    2005 Tuono Factory
    Likes Marin Moto Works
    SaferMoto
    RIP Kenny The Iceman #12
    apriliaforum prov-nov blurry's Avatar
    Mar 2009
    syracuse, ny
    Thinking too much, put them on a go. bleed your brake fluid while you are at it - and put in something decent like motul - Make sure it is DOT4
    NESBA #32
    2008 Aprilia RSVR - Street bike
    2006 GSXR 750 - Track Bike, lots of goodies
    1991 YSR50 - 49cc's of smoking fury
    2007 KLX110 pit bike
    Jul 2007
    Netherlands
    Being a hydraulic system the caliper will automatically compensate for the thinner pads.
    Jun 2011
    Thanks guys. Was thinking that inside or outside pads consistently wore faster than the other side, I would put the fatter ones there. I'm going to worry about bigger things...
    2005 Tuono Factory
    SaferMoto
    Mar 2011
    Baton Rouge
    Quote Originally Posted by jmardy View Post
    That what I do, rotate them just like cage tires to extend service life after pulling them to clean the caliper pistons. A little off topic but do you have a method for rotating the pistons so the entire circumference can easily be accessed for cleaning? I use isopropyl alcohol and Q-tips on wooden sticks to clean the pistons. But I can't easily get to the entire surface and so far I can't rotate the pistons with my fingers. I'm thinking about maybe next time trying to extend some angle needle nose pliers inside the pistons to get them to rotate. So just wondering if you have any tricks for this?
  1. AA500 Front Brake Pads Different!
    By Skullman in forum Aprilia and Piaggio 500cc
    Last Post: 08-21-2011, 02:31 PM
  2. How many miles do you get out of your front brake pads?
    By DolbyGuy in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 01-19-2009, 10:02 AM
  3. wich front brake pads to buy ???
    By minibrute in forum SL1000 Falco Forum (all years)
    Last Post: 03-19-2004, 04:16 PM
  4. Head bearings and front brake pad replacement
    By 02Prilia in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-03-2003, 01:07 PM
  5. Front Brake Pads
    By silvercapo in forum ETV1000 CapoNord (all years)
    Last Post: 02-15-2003, 08:49 PM
