Results 1 to 4 of 4
Thread: Fuel pump will not prime
    apriliaforum Member bigbrit71's Avatar
    Oct 2007
    Just put a v255 chip in and the fuel pump will not prime
    It worked before I changed the chip and worked when I put the old chip back in any ideas?
    I have seen a post about this prob before
    I have pmed gabro to
    Oct 2007
    Sorted it
    apriliaforum expert DanV990's Avatar
    Stroudsburg, PA
    Did you put the chip in backwards or did you forget to remove the daughter board? My bet is daughter board.
    BTW v255? Do you mean F255?
    2000 Tricolor, KTM Sprag, 16/43 sprockets, D.I.D. 525 Gold Chain, Rick's Stator version 2, RP collector modified with dual link pipes, Gabro F255 EPROM, Akrapovic slip on, Ohlins radial front forks, Falco clip-ons, 16mm Brembo radial brake master cylinder, Brembo four pad radial brake calipers, BrakeTech Axis ductile iron brake rotors, Integrated LED brake lights & blinkers, Ohlins rear shock with remote preload adjuster, Longer RS125 mirrors so I can see more than my shoulders and elbows.
    Oct 2007
    Not push the plugs in enuff no daughter board just me being a num nut nowt else
  1. Installed Gabro's chip now my fuel pump won't prime
    By Troy_v in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 04-22-2012, 09:41 PM
  2. New Gabro Chip, but now fuel pump will not prime???
    By Dr. Zaius in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 05-15-2010, 08:50 PM
  3. Fuel pump not priming
    By Markee in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 02-15-2009, 05:07 AM
  4. Fuel Pump dowsn't prime.
    By FalcoLion in forum SL1000 Falco Forum (all years)
    Last Post: 07-16-2008, 07:06 AM
  5. Fuel pump pressure not starting...What should it be?
    By jbru167 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-11-2006, 12:48 PM
