Results 1 to 15 of 15
Thread: Is an excact match for Futura colors impossible?
    apriliaforum Member Corkus's Avatar
    Jun 2011
    NorCal - East Bay Area
    I expect it is not possible to get an exact match for a Futura color. Aprilia doesn't give out paint codes? Of all the trade secrets in the world I don't get that one.
    I found these two paint codes here. I would be happy to be wrong but I expect these are codes some guy came up with to match the factory paint.
    Futura Silver
    01 & UP
    APR-2JCXB
    Flame Red
    02 & UP
    APR-2VHBB
    So all the factory paint is fading now and there's no way to accurately repaint? Except to have someone eyeball the paint color?
    And maybe it isn't possible to re-create the factory paint anyway? It says here "Both Flame Red and Stream Silver are made up of four coats of different colours."
    Cory
    02 Futura
    Pleasanton California
    Connecticut
    Not all of it is fading. The Ash Black on my 02 still looks like new. One advantage of starting with a satin finish color.
    John B.
    apriliaforum expert shannon's Avatar
    Aug 2005
    Knoxville,TN
    Being as Aprilia doesn't release paint codes I would call him and ask how he came up with the numbers. I'm not saying they aren't close or even a perfect match I would just want to know how he came about matching the paint before I spent any money with him.
    Current:
    02' Futura: Staintunes, H-pipe, Firebolter air kit, Corbin w/backrest, Mille forks, mille rotors, mille calipers, ss braided brake & clutch lines, MPL clutch slave cylinder, brembo radial master cylinders, license plate bracket chop, charcoal cannister removed, fork sliders, R&G frame sliders, throttlemeister, smoke windscreen, air box derestricted, mille air boot, stomp grip tank pads, anodized gas cap bolts, Ford starter relay, Ballistics lithium battery, helmet lock, carbon rear mud guard, Marsee corona tank bag, filler cap mod
    04' RSVR Track - In part out mode
    apriliaforum Junkie threeviews48's Avatar
    Jul 2010
    UK
    Ask your local paint distributor if he has a spectrometer, if so they will be able to get an exact match
    Mar 2012
    Northwest USA
    Quote Originally Posted by threeviews48 View Post
    This is only partially accurate as the spectrometer averages out a small area of what's sampled, and the real issue is fading - rendering an area average (for example the top of the front fender) somewhat useless. My '01 Stream Silver is about 5 slightly different shades. The fading seems to vary quite a bit based on the underlying substrate and where it is on the bike in relation to the fading effects of light. I think that the original paint quality may have been shit to start with, but that's just my worthless opinion.
    I repainted both panniers as the left one had a little garage rash from the original owner, and found a damn close match in Deltron (a PPG paint). I'll post some pics this evening, as well as the paint code for whomever...
    A self-professed master of nothing
    '01 Futura
    SV 650 Track bike
    apriliaforum expert flying fox's Avatar
    Apr 2008
    Stockton-on-Tees,UK
    Waiting....
    ...and what is Deltron?
    04 Silver,Derestrict Airbox,Mille Boot,Reg/Rec Mod.,05 Map,Heated Grips,Smoked Screen,Beftura Forks,HID Headlight,Stone Chips,Scratches...
    Where there is a will...There is usually a dead relative!
    The Art of Bodge-It Never Fails.
    Aug 2005
    Knoxville,TN
    Quote Originally Posted by flying fox View Post
    Waiting....
    A brand of paint.
    Current:
    Mar 2012
    Northwest USA
    Waiting....
    Work is holding me hostage...
    '01 Futura
    SV 650 Track bike
    Mar 2012
    Northwest USA
    This photo makes the differences in fading look far worse than they really are, but there are differences in the shades in the highlighted areas.
    The 2 pics showing the panniers are to depict their likeness to the seat surround trim - I painted the panniers to fix some garage rash on the left one,
    The paint I used is Deltron DBC 2000, Color code 925906 called Glacier Blue
    While it's not identical, it's damn close and I'll probably paint the whole bike with it this winter anyway
    Oh, ignore the spots on the panniers - those aren't paint flaws. They're the little bodies of bugs who committed triple-digit suicide on Thursdays' ride.
    Name:  Futura paint 1.jpg
    Name:  Futura paint 2.jpg
    Name:  Futura paint 3.jpg
    '01 Futura
    SV 650 Track bike
    Apr 2008
    Stockton-on-Tees,UK
    That's close,alright!I only need the panniers doing - do they do rattle cans?
    Mar 2012
    Northwest USA
    Not that I'm aware of, and it ain't cheap but it's good stuff.
    '01 Futura
    SV 650 Track bike
    PA USA
    My Stream Silver came from the factory with 3 different colors. The tank is very silver. The rest of the fairing is a bit bluer. And there was one lower panel that was really a shade greener and did not match at all. Mine's been garage kept it's entire life. Not sure that it's really faded at all.
    apriliaforum Member DrFutura's Avatar
    Apr 2009
    North Wales
    When mine was repaired after a drop in 2010 the colour on the left has come back different, and the finish is not the same. Its flame red. The best you can do maybe is find a sprayer with an "eye" for the colour who will mix his own. Some of the older paint sprayers seem to be able to do this having gained experience over many years. Unless you are doing a whole panel I would not bother trying to blend in with the original.
    Trust me! I AM a doctor!
    Carthage, NC
    I wish. They can only do basic colors at most stores and when it comes to candies, forget it.
    I have a piece I am going to be sending into the Kustom Shop, who offers a matching service. If they get it right, I will let you know.
    The biggest issue with this color is that it's a candy over a base, but that candy is not just red. As well know, it has an orange tint to it as well, which is why it is so difficult to match up. Coupled with the fact that th efactory color is so prone to fase, forget matching a panel. A total repaint is going to be required for it all to match. I have been playing with some candies trying to get close, but so far, nothing is what I would consider satisfactory.
    Ron
    MSgt USMC (Retired!)
    Semper Fi!
    Nesba A #45
    IBA #38812
    RST Futura
    RS50
    PA USA
    I thought someone a while ago figured out what the base and candy coats were for the red.
  1. Replies: 8
    Last Post: 11-27-2007, 09:39 PM
  2. Buying an Mille engine for the Futura...
    By ride200mi in forum RST1000 Futura (all years)
    Last Post: 12-30-2004, 11:19 PM
  3. Here is an interesting Hybrid for you guys!
    By Micah / AF1 Racing in forum RS50 Technical
    Last Post: 08-10-2004, 10:31 AM
  4. Is This An Arrows Pipe For 2000 Rs?
    By apriliabran in forum RS125 Euro-archive
    Last Post: 09-23-2003, 07:07 AM
  5. hard anodized is a perfect match for the tuono frame
    By ApexMolester in forum Aprilia Owner's Pictures, Videos, and Sounds
    Last Post: 05-11-2003, 02:39 PM
