Results 1 to 3 of 3
Thread: roller wheigts
    Jun 2012
    Germany/Berlin
    roller wheigts
    Hello.
    I have a problem.
    I bought an Gianelli Extra and a Multivar2000.
    installed is an Malossi FlyClutch with yellow springs and a lighter clutch bell from Stage6.
    Stock roller wheigts (5,3gr)
    For Gianelli people says, you need lighter roller wheigts - 4,x gr
    For Multivar2000 people says, you need heavier roller wheigts - 6,1gr
    So which roller wheigts I need for both?!
    apriliaforum expert Alexandar's Avatar
    May 2011
    Skopje, Macedonia
    if you had the original variator you will put the rollers that came with the exhaust but with multivar heavier try the 6.1 and the stock 5.3
    SR DiTech Piaggio c361 2005
    Polini Kit 70cc
    Polini Bowl
    Malossi Multivar 2000
    Original Piaggio Contra Spring
    Rollers Malossi HT 7.5 grams
    Malossi Special Belt
    Malossi Oil 7.3 & Agip City 2T
    Malossi Gears HTQ 14/39
    Gianelli Reverse
    Air Diffuser 20mm
    Clutch Stage6 Torque Control MKII
    RMS Crank
    Woodruff Key 3degrees
    Malossi Air Filter
    Polini Carbon Reeds 0.35
    Water Trap
    Fuel Pump Mod
    Ecu Derestricted version 2.8.0
    Spark Plug NGK ZMR7AP
    Sava MC 29 Sporty 3+
    Lights Philips Master LED spot LV 10wx2
    Brembo brake pads
    Jun 2012
    Germany/Berlin
    Multivar2000 includes 7,2gr, Gianelli includes 4,x gr... stock I have 5,3gr. So I would try 5,3gr and after that I decide to buy an 24pieces roller-set.
  1. Got some heavier roller weights installed on the 'Beo
    By jj008 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 06-30-2003, 11:23 AM
  2. Rollers HELP!!!!!!!!
    By Andrea Head in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 06-25-2003, 11:54 AM
  3. Arrow pipe for SR50 Ditech...what gm rollers?
    By Duc995 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 06-18-2003, 10:44 AM
  4. 4.7 and 7grm rollers in my variator
    By stevodel in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-24-2003, 08:25 AM
  5. FYI...roller weight weight
    Last Post: 05-20-2003, 06:55 PM
