Page 1 of 7 123 ... LastLast
Results 1 to 15 of 103
Thread: Map list of members and where they are located.
    Vancouver BC
    I am trying to get a better understanding of where everyone is located.. I created this map. I hope it works out.
    I will be the admin for now.. if this is not allowed just delete the thread and let me know.
    Just click on..
    AF1 Aprilia SR50 Forum Members
    You do not need to register to add your location
    Click on additions and pick symbol and put where you are located. I use my Forum name to say who I am.. Post as much detail as you like.
    apriliaforum expert Cool77's Avatar
    Drummondville,Quebec
    Cool app
    Aprilia SR Factory 50 2006 IE Morini Engine type
    13 500KM
    MAX Speed after rod in 92KM/H flat no wind, 104 KM/H tuck
    Malossi BBK + Full Circle Crank since 10 287KM
    Stock Gears
    ECU : Malossi
    Mod : Leo Vince ZX-R Pipe flat black ceramic coated - HGT regulator Gen III - Malossi multivar 2000 - 9.0gr Dr. Pulley rollers - Malossi delta clutch small white spring big white spring w/o tc - Malossi belt - Malossi red foam air filter - ZMR7AP plug - Water trap - Malossi Reed valve VL-12 - Buzzetti side stand - YSS Rear shock.
    Sep 2008
    I reject your reality, and substitute my own. CANADA
    Just added my Info...
    Tempus Fugit
    apriliaforum Member nexlvlsh!t's Avatar
    May 2012
    Vancouver
    Approve meh!
    2007 SR50 Factory
    Reed valve -MALOSSI MHR VL14 Aprilia 50cc Morini - carbon fiber
    Malossi multivar 2000 Morini
    Porter Cable Water Trap
    Woodruff key -TOP PERFORMANCES 3x5mm- Morini 50cc 2-stroke
    Exhaust -LEOVINCE ZX-R- DiTech LC (Morini) Installed 06/01/2012
    Stickers Removed
    Derestriction ECU map 2.8.2
    HGT Gen III Fuel Regulator
    LED Headlights
    Custom License Plate LEDS
    Malossi Air Filter
    Malossi Belt
    Dr Pulley 7.0g Sliders
    Vancouver BC
    done and done.. this is looking good already! soon we can put routes taken.. so other members could try that same route for a fun ride.. etc.. or shops and Info etc
    Could we make this a sticky? World map of Members?
    Looks like Canada rocks this one.. or Americans are paranoid... lol
    Sep 2008
    I could put it in the Sticky "Read Me First!" where we have the Polls sitting...
    Tempus Fugit
    Vancouver BC
    That would be a good idea. Be a great way to know how close members are and then they can get together for rides or help each other out.
    For now lets keep it here to get the ball rolling most regulars wont check the read me first for this.
    Knoxville, TN
    Great Idea!
    SR50 R Factory / 2009 / Piaggio Purejet
    _Fully Derestricted
    _Leo Vince ZX-R Exhaust w/included Rollers
    _NGK ZMR7AP Spark Plug
    _Kolbalt Water Trap
    _55 MPH on Flat
    _7700 miles
    Vancouver BC
    Make sure you throw your self on there..
    Oct 2011
    Sidney, B.C.
    Just added myself twice. Once without logging in, once after I did log in.
    Rossco, toss one of my entries, you choose.
    ________________
    '07 SR50 Factory (Morini) - ZMR7AP gapped to .035
    Leo Vince ZXR, 7.75 gram Dr. Pulley sliders,
    ECU: 2.8.2 Developmental via Gameboy; Malossi Multivar with white contra spring
    Norgren F07-200-M1TA soon
    Malossi special belt (Morini) (P/N 6111295)
    86+ km/hr on speedo untucked, flat road as best I can tell.
    Vancouver BC
    All approved. I kept the one with the most detail.. this map should look good in a few days.. Really shows the depth of this scooter and where people use it.
    Vancouver BC
    Early morning
    apriliaforum expert Alexandar's Avatar
    May 2011
    Skopje, Macedonia
    Ive added myself but this is very easy if someone wants to steal the scooter since ive added myself on the street where i live heheh
    SR DiTech Piaggio c361 2005
    Polini Kit 70cc Polini Bowl
    Malossi Multivar 2000 Original Piaggio Contra Spring
    Rollers Malossi HT 7.5 grams Malossi Special Belt
    Elf Moto Tech2 Malossi Gears HTQ 14/39
    Gianelli Reverse Air Diffuser 20mm
    Clutch Stage6 Torque Control MKII RMS Crank
    Woodruff Key 3degrees Malossi Air Filter
    Malossi VL13 0.30mm Water Trap
    Fuel Pump Mod Ecu Derestricted version 2.8.0
    Spark Plug NGK ZMR7AP Sava MC 29 Sporty 3+
    Lights Philips Master LED spot LV10w
    Brembo brake pads Stage6 Disk 260mm Aprilia Raceing Shock "Paioli"
    Vancouver BC
    I can edit it to hide the street address
    apriliaforum expert TheChef's Avatar
    Aug 2010
    Surrey,B.C
    Done.
    09 SR Factory
    "Boo"
    Malossi BBK
    2.8.0 ECU LEOVINCE ZX-R ZMR7AP .035
    MALOSSI Multivar 2000 Yellow BGM clutch springs Green contra spring Reeds VL13
    8gm Dr Pulleys Husky Watertrap
    Gen III Adjustable High Gain Tuning Regulator 118psi
    Woodruff key BGM pod filter
    Fuel pump fix 40mm riser Stretch kit
    113kph.
    6"3 225lbs.
  1. AA200 list of parts and pricing
    By maxgt33 in forum Aprilia and Piaggio 500cc
    Last Post: 08-16-2006, 01:54 PM
  2. How old are you and where do you live?
    By hybrid-RS50 in forum RS50 Technical
    Last Post: 11-14-2005, 05:39 AM
  3. who was it that had a list of left over 02 and 03 models?
    By Caponerd in forum ETV1000 CapoNord (2001-2007)
    Last Post: 12-11-2004, 03:36 PM
  4. wat a piece of piss! and the feds are bastards!
    By alitam in forum RS125 Euro-archive
    Last Post: 09-23-2004, 02:00 PM
  5. Full list of bits needed to replace piston and rings any1???
    By technoandy in forum RS125 Euro-archive
    Last Post: 05-19-2003, 02:59 PM
