Results 16 to 23 of 23
Thread: Help with throttle body linkage
    Feb 2009
    Tri-Cities, Washington
    Linkage bar is all that is needed.
    Jun 2012
    Greece
    hmm thanks
    Feb 2009
    I think it may also need a bolt and washer, but it's trivial.
    Mar 2012
    Seville. Spain
    And a map for the Async Throttle... In my case the Async linkage is the OEM one with one hole elongated.
    But I can not recomend you to do this because the linkage has no part number and if you modify the OEM one you can not go back.
    Thats my case and I had to buy an used injection bodies to get the OEMlinkage...( now I have some spares for my injection)
    Cheers
    Jun 2012
    Greece
    hmm i just wanted to learn about this thing
    i dont really want the asymmetric tbs.. i would just like the 40mm tbs over my 38s
    Southern California between Los Angeles and OC
    Quote Originally Posted by pacote View Post
    The Asymmetric link plate is indeed available from Aprilia
    p/n 855237 for the 450
    p/n 855238 for the 550
    They are not so easy to find but should be available in Italy, I got some a few years ago but don't have any left.
    Aprilia Moto Service 714 892-4056
    Mar 2012
    Seville. Spain
    Hi amauri I was talking about NOT modify the OEM SYMMETRIC link plate INTO ASYMMETRIC ONE because I could not find the part number for it (the Symmetric) and I had to look for used TBs to get one.
    With this information is better to buy one of these instead of modifying the original one.
    Thanks for the info.
    Yes, this way you can experiment and go back to stock if you don't like it.
  1. help with rear shock linkage removal guide
    By tomzek in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 03-02-2012, 12:11 PM
  2. grub screws on throttle bodies linkages
    By fredgreen in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 05-09-2009, 12:42 AM
  3. Help with throttle slide
    By 1CEMAN in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 09-04-2006, 11:58 AM
  4. 54mm throttle bodies - Sync - reset TPS - Need help
    By RSVKlimaxx in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 05-25-2005, 05:13 AM
  5. are throttle bodies interchangeable with RSV?
    By JoksaR6 in forum RST1000 Futura (all years)
    Last Post: 06-17-2003, 01:24 AM
