Results 1 to 5 of 5
Thread: Tps set up ?
    apriliaforum expert BB1000's Avatar
    Jul 2006
    UK, Bedford
    Tps set up ?
    does this need any special axone set up
    throttle feels jerky up to 3k but fine when warm and riding
    Jul 2007
    Netherlands
    Both the tps and the aic can be reset using the axone or navigator. This only needs to be done after switching ecu, tb or aic
    Feb 2009
    When you replace either the tps or ecu, it kinda sets itself up in 'default' mode. The bike will run ok, but it's nowhere near as good as it should be.
    Jul 2006
    UK, Bedford
    cheers peeps
    Aug 2011
    3rd rock from the sun
    Quote Originally Posted by BB1000 View Post
    You need the services of someone with Axone/Navigator to connect to and tell the ECU to "Learn" the TPS parameters. This applies any time the TPS is touched.
    If this is a new problem, there are a number of things might cause wonky low speed running.
  1. Replies: 6
    Last Post: 11-06-2007, 04:20 PM
  2. Suspension set up 96 model
    By beanarillo in forum RS250
    Last Post: 06-18-2003, 11:47 AM
  3. Suspension Set-up
    By ncrs250 in forum RS250
    Last Post: 06-15-2003, 03:43 AM
  4. Newbie: RS250 Track Set Up
    By dutchieindublin in forum RS250
    Last Post: 04-30-2003, 09:07 AM
  5. HELP SETTING UP FOR LOMAS PIPES!!
    By chrisiball in forum RS250
    Last Post: 04-14-2003, 02:59 PM
