Page 1 of 5 123 ... LastLast
Results 1 to 15 of 68
Thread: hmmm, wont start?
    apriliaforum expert ryanperkins's Avatar
    Dec 2011
    kettering
    Question hmmm, wont start?
    righ so my completely standard rs50 bump started fine the day we brought it (battery was dead), got it home switched the battery out started off the button straight away went out today to start the bike it was just turning over, checked the battery and its fully charged, swapped the plug out too my old race plug off my other rs50 cant remember what letters it had but it was an 8 something :L the one that was in it was a 5 something :O
    wouldnt start, checked there was spark.. wouldnt start, swapped for old starter motor (very noisy but never let me down) still wouldnt start so i stuck on the original quite one, still wouldnt start! so i gave up and went out for dinner
    my blue rs50 did this when i first got it (all standard also, and it always started by bump :L) i then had my 19.5mm carb on then the problem was never heard off again!
    so am i right in thinking maybe the carb needs a clean? i will be putting the polini 19.5mm carb onto this one anyway :L but just wanted to check
    what do you think off mine? comments please!!
    apriliaforum expert Glen1990's Avatar
    Nov 2011
    Barrow in furness
    Was the plug wet clean the carb and if it was me I'll just swap everything over off your other bike the engine carb exhaust
    Aprilia rs 50 2000
    Top performance Pink 75cc
    Doppler Endurance crankshaft
    Arrow racing exhaust with carbon endcan
    Dellorto 21mm carb(92 main jet)
    Stock air box modded
    Top performance Cdi
    Malossi reed block 0.30mm
    Conti race clutch kit
    14/47 Gearing
    Mono rear
    Michelin pilot sport tyres
    Rs 125 front master cyilinder
    Malossi upgraded clutch springs
    Rs 125 Headlight
    UPGRADES to come
    24mm mikuni flatside carb
    Double bubble screen
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    Full respray and frame polish
    Doppler air rear shock
    Sep 2011
    warrington uk
    wait you put a 8 in there?? and there WAS a 5 in there??
    stock rs should be B(R)9ES, use the right plug and it might start
    with your polini kit you may well need to use a 8 but not with a stock one
    and clean carb out, easy quick job so just rule that out too
    Engine Always Screaming!
    Dec 2011
    kettering
    Quote Originally Posted by Glen1990 View Post
    i am just not yet :PP
    YES it was a 5! ill upload a picture of it later, i was well shcked when i found out (was only gunna check the colour and check if there was spark so good thing really) and yeah but its a race plug and its what pmtuning recommened it... before i had my polini cylinder :P
    with the polini one i had a 95 in there because it was constantly running at high rpm's so it could stand the heat better, its what patrick recomended
    apriliaforum Junkie EJD's Avatar
    Apr 2012
    Dronfield, Derbyshire, UK
    Might be a stupid question but will it BUMP start now?
    Don't think you mentioned weather it bumped now or not.
    Dec 2011
    kettering
    yeah it will bump all day long :L
    thats why im confused :L my blue one done this when i first got it until i changed the carb :s
    apriliaforum Junkie nicketynoo's Avatar
    Oct 2011
    scunthorpe
    Sounds to me like the starter isn't actually turning the engine over!
    1999 rs50
    standard 50cc barrel+piston
    12mm phbn carb 86 main jet
    standard airbox
    conti racing clutch+uprated springs
    exhaust- Gianelli-carbon end can
    reeds- not sure
    bank account-empty
    apriliaforum expert mumbl3s's Avatar
    Jan 2012
    kent, uk
    Quote Originally Posted by nicketynoo View Post
    yeah im with nicketynoo on this one, or mabey it's just not turning the engine over quick enough - try jacking the back wheel up and put her in gear they push the start button and see if the tire turns
    Warming the world 2 strokes at a time.
    <- *check out the BMX with a 50cc engine *
    2008 rs50 - SOLD
    Dellorto - PHBG 21mm tuning carb
    Arrow Exhaust - not sure which one
    Doppler - D50B0 Endurance crankshaft
    Italkit - 74cc cylinder kit
    Malossi - 0.40m reeds
    Malossi - upgraded clutch springs
    2006 gz125 - Winter Bike
    No Upgrades
    1981 CB250N (30BHP Version) - In Restoration
    Going to be a Cafe Racer with a modern twist!
    Sep 2011
    warrington uk
    or just take the flywheel cover off and watch the starter bendix engage with the spinning flywheel
    probs not enough life in the battery, there only little
    Nov 2011
    Barrow in furness
    ill say not enough lift in battery too even when its low it can spin it but not fast enough
    Aprilia rs 50 2000
    Top performance Cdi
    14/47 Gearing
    Mono rear
    Rs 125 Headlight
    UPGRADES to come
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    Dec 2011
    kettering
    i swapped the starter motor off my old one which ALWAYS worked! but still didnt start it so i swapped it back over because it rattled and was super noisy :L
    i think this right :L im gunna charge the battery then see what happens :P
    Sep 2011
    warrington uk
    id get all your new stuff fitted first mate, you say on your old bike you changed your new carb and the problem never recured so im thinking its the shitty dellorto sha 1412 carb causing you problems (you said its completly stock right?)
    Dec 2011
    kettering
    Quote Originally Posted by chrism15 View Post
    yup completely stock
    Nov 2005
    Netherlands
    Think you might want to swap the starter engine out with your other bike and see if that helps mate.
    Apr 2012
    Wait a second, my mate had a similar issue with his Moped.
    It was something to do with one of the wires that recharges the battery when the engine is ticking over (have no clue what this process is called)
    maybe that is something you could take a look at.
    The issue caused a lack of power (electric) going throughout the moped and caused everything from starter motor/lights/speakers and neons not to work properly.
    My Setup :
    Doppler Vortex 50cc Performance Kit £174
    Doppler WR7 Exhaust Kit £174
    Polini 19.5 Chrome Carb £115
    Polini Race Clutch Kit £54
    NGK BR10EIX Spark £10
    Polini Air Filter Sheet £11
    Doppler Grips £15
    Extra Parts:
    Road Angle Professional Connected £300
    Garmin Sat-Nav (bike) £89.99
    Cyclone C-11 Bike Alarm System £23.99
    Aprilia RS50 1999
  1. Bike wont start HELP!!!!!
    By rob mcconnell in forum Pegaso 650 Cube and IE
    Last Post: 09-30-2003, 04:12 AM
  2. Bike wont start
    By r1y2k in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-19-2003, 11:44 AM
  3. Scarabeo wont start after few hours of parking. Help please!
    By azlanmhadi in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 06-10-2003, 09:00 AM
  4. won“t start/ idle correct, soft kinda scratching noise
    By sandbergdenmark in forum RS50 Technical
    Last Post: 05-17-2003, 04:16 PM
  5. got a new sr that wont start???
    By Farmerwardy in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 12-18-2002, 04:27 AM
