So today I took off the front cover to get into the area where the radiator/coolant/brake valve is, have done this a few times before no dramas.
Anyway once I screwed it back on and put it in place, all seemed fine. Later on I noticed I now have a large 10-15cm crack where the red fairing - glove box compartment door has cracked from the bottom upwards, and now have a gaping big crack in my Beo !!!![]()
The scooter did not fall over or anything, I have absolutely no idea how it could happen. The only thing I can think of is did I overtighten the screws when I put the front cover back on, I can't remember if I had the glove box door open and then later shut it after tightening the front cover, or what I did, but this is all I can think of..
It's probably a newbie 101 mistake..overtightening thingsI've learnt my lesson now (if that actually is what happened to cause this), just don't want screws coming loose or falling out that's why I put em in tight.
Now is there any way to repair it or put something in the crack to stop it spreading, should I super glue it or something? I found the part# for a new one - JC921519200005E - but it's around $100+not a good day
