Results 1 to 14 of 14
Thread: RS50 Xenon Lights? (is it possible?)
    apriliaforum Junkie EJD's Avatar
    Apr 2012
    Dronfield, Derbyshire, UK
    I have been looking on line for the past few hours trying to find out if you can use an xenon light (not a blue tinted light) will work on a RS50.
    I believe it has to be 50watts but would I have to buy one of those HID kits ($100+) like the one I have linked below?
    Cheers
    HID Kit For RS50:
    http://www.hidkitsxenonlights.com/ap...dlights-bulbs/
    apriliaforum expert Glen1990's Avatar
    Nov 2011
    Barrow in furness
    if you had the older model of the rs before 2006 just fit the 125 headlight its great
    Aprilia rs 50 2000
    Top performance Pink 75cc
    Doppler Endurance crankshaft
    Arrow racing exhaust with carbon endcan
    Dellorto 21mm carb(92 main jet)
    Stock air box modded
    Top performance Cdi
    Malossi reed block 0.30mm
    Conti race clutch kit
    14/47 Gearing
    Mono rear
    Michelin pilot sport tyres
    Rs 125 front master cyilinder
    Malossi upgraded clutch springs
    Rs 125 Headlight
    UPGRADES to come
    24mm mikuni flatside carb
    Double bubble screen
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    Full respray and frame polish
    Doppler air rear shock
    Apr 2012
    Quote Originally Posted by Glen1990 View Post
    Oh! Is it all the same wattage or not? And will it drain the battery if I use it?
    Nov 2011
    Barrow in furness
    they are h1 bulbs 55w i have them fitted on my rs 50 only thing is when your sitting at low rpm the light goes lower but they are soo dam good
    Aprilia rs 50 2000
    Top performance Cdi
    14/47 Gearing
    Mono rear
    Rs 125 Headlight
    UPGRADES to come
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    apriliaforum expert ryanperkins's Avatar
    Dec 2011
    kettering
    easier said than done.... theyre bloody hard to get hold of
    what do you think off mine? comments please!!
    Nov 2011
    Barrow in furness
    i saw a few on ebay
    Aprilia rs 50 2000
    Top performance Cdi
    14/47 Gearing
    Mono rear
    Rs 125 Headlight
    UPGRADES to come
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    Sep 2011
    warrington uk
    he has the old type
    99 - 05 Aprilia Rs 125 headlight will work better, ebay is probs best bet - in fact you can even have the full Rs 125 front nose cone! if you want a bit bigger look
    Engine Always Screaming!
    Nov 2011
    Barrow in furness
    the 125 nose cone is totally the same as the rs 50 one? :S
    Aprilia rs 50 2000
    Top performance Cdi
    14/47 Gearing
    Mono rear
    Rs 125 Headlight
    UPGRADES to come
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    Nov 2005
    Netherlands
    yeah, aand the rear end is the same also, undertray, rear end, passenger seat, and the cover for the glove compartment, only the RS125 has the little pillow on that wich you can fit on the 50 also.
    Apr 2012
    Quote Originally Posted by chrism15 View Post
    he has the old type
    Do they make a noticeable difference?
    My Setup :
    Doppler Vortex 50cc Performance Kit £174
    Doppler WR7 Exhaust Kit £174
    Polini 19.5 Chrome Carb £115
    Polini Race Clutch Kit £54
    NGK BR10EIX Spark £10
    Polini Air Filter Sheet £11
    Doppler Grips £15
    Extra Parts:
    Road Angle Professional Connected £300
    Garmin Sat-Nav (bike) £89.99
    Cyclone C-11 Bike Alarm System £23.99
    Aprilia RS50 1999
    Sep 2011
    warrington uk
    better headlights so iv been told
    Nov 2011
    Barrow in furness
    yeah they are alot brighter better bulbs and have a projector
    Aprilia rs 50 2000
    Top performance Cdi
    14/47 Gearing
    Mono rear
    Rs 125 Headlight
    UPGRADES to come
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    Dec 2011
    kettering
    i saw a few on ebay
    :O where i couldnt find any on there the two i found when you read the description said its a different light to the one in the image so it was rs50 one another went for 60quid and i didnt have the money at the time
    Nov 2011
    Barrow in furness
    yeah your right the ones i were looking at said that too i found two but both were £100 wow i didnt know they cost that much
    Aprilia rs 50 2000
    Top performance Cdi
    14/47 Gearing
    Mono rear
    Rs 125 Headlight
    UPGRADES to come
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
  1. rs50 rear brake light : is it possilbe to get a LED one?
    By Matt_151 in forum RS50 Technical
    Last Post: 01-16-2011, 10:45 PM
  2. Is it possible to get a non-USA model into the USA?
    By bcwatson in forum Non-USA model Aprilia Scooters
    Last Post: 06-20-2004, 10:17 AM
  3. So is it possible?
    By TwoWheeldTerror in forum RST1000 Futura (all years)
    Last Post: 01-18-2004, 12:30 AM
  4. Is It Possible to......
    By ThugSTar910 in forum RS50 Technical
    Last Post: 12-17-2003, 05:22 PM
  5. Is it possible ever to derestrct and restrict while riding?
    By larryep in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 03-15-2003, 12:08 PM
