Thread: how hard is it to fit the tank and seat of a 06+ onto a 04?
    apriliaforum prov-nov Harrison Dobbie's Avatar
    Jun 2012
    northamptonshire
    i am interested in fitting the seat and tank of a 06+ onto my am6 engined 04, is it a lot of work?
    04 Rs50 75mph
    pm tuning custom powerpipe
    polini evolution 80cc with boost ports
    full circle race crank
    polished rod
    Sep 2011
    warrington uk
    hmm im not sure but i think the tank is very easy to swap over, i was considering doing the same thing a few months back as the new type tank looks great! maybe send "JimmySR" a message as he has converted the 98 model by adding a 2006 rear end and tank!
    link here to his thread:
    http://www.apriliaforum.com/forums/s...ject-to-06-gt-)
    Engine Always Screaming!
    apriliaforum expert Glen1990's Avatar
    Barrow in furness
    Quote Originally Posted by chrism15 View Post
    yeah but he wants to know the 2004 with the 2006? thats the older rs he did
    Aprilia rs 50 2000
    Top performance Pink 75cc
    Doppler Endurance crankshaft
    Arrow racing exhaust with carbon endcan
    Dellorto 21mm carb(92 main jet)
    Stock air box modded
    Top performance Cdi
    Malossi reed block 0.30mm
    Conti race clutch kit
    14/47 Gearing
    Mono rear
    Michelin pilot sport tyres
    Rs 125 front master cyilinder
    Malossi upgraded clutch springs
    Rs 125 Headlight
    UPGRADES to come
    24mm mikuni flatside carb
    Double bubble screen
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    Full respray and frame polish
    Doppler air rear shock
    Sep 2011
    warrington uk
    pretty sure the frame is the same or very close too
    i was going to do it on my 99 Rs
    Barrow in furness
    i dont think it is that close not sure dont know much about the old model
    Aprilia rs 50 2000
    Top performance Cdi
    14/47 Gearing
    Mono rear
    Rs 125 Headlight
    UPGRADES to come
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    Jun 2012
    northamptonshire
    Quote Originally Posted by Glen1990 View Post
    i heard somewhere it was just a case of changing the rear subframe, i know the 2011+ rs4, its the same actual frame, with a different swinging arm, not sure about the 06-11 ones though, i hope they are!
    04 Rs50 75mph
    polished rod
    Sep 2011
    warrington uk
    i can understand why you"d need to change rear swing arm as the length of new tank may be longer so the rear bracket will need to be further back but then the quistion is asked "willl the 99-05 model rear end/tail fit on a 06onwards> swingarm?" unless you want the new type tail aswel
    "JimmySR" has fitted the new type tail and tank to his 97 model so it is doable
    the new type tanks look the bollox though
    Nov 2005
    2006 seat is horible compaired to the <2005 seat, but it wont fit on there anyway with out serious modifications to the subframe, fueltank is nearly imposible to fit on the aluminium frame, i even think the tank is to narrow for the frame.
  1. Two questions. How hard is it to fit an H-pipe and
    By Solihull in forum RST1000 Futura (all years)
    Last Post: 09-24-2008, 07:23 AM
  2. how hard is it to rebuild and tune the am6
    By rieju in forum RS50 Technical
    Last Post: 11-02-2007, 04:27 AM
  3. how hard is it to swap springs
    By chris123 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 03-08-2007, 06:31 PM
  4. How hard is it to apply decals?
    By benji2909 in forum RS50 Technical
    Last Post: 03-24-2006, 10:38 AM
  5. How hard is it to redo the forks? New springs and valve kit.
    By mysubaruimp in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-30-2005, 02:01 PM
