Results 31 to 45 of 75
Thread: Air box setup for the Mille
  1. #31
    apriliaforum newb Toastrider's Avatar
    Aug 2011
    Essex UK
    I was told the topend power was limited by the valves
    But it has the biggest effect on the midrange power
  2. #32
    Canyon Lake, TX USA.
    You can datalog your MAP sensor to see what your high speed air density is...some very interesting stuff to be learned there if you do it. Technically the stock MAP sensor is 1 bar or 0-14.7 psig but they are usually good to about 15-16 psi Total air pressure, if need more resolution then you can easily add a second 1.5 BAR map sensor and log it. Air temp inside the airbox near the intake trumpets is also interesting to look at, in traffic and on a hot day MUCH higher than you might expect.
    Micah Shoemaker
    699 W. San Antonio
    New Braunfels, TX 78130
    830-626-3966
    micah@af1racing.com
  3. #33
    Aug 2011
    Essex UK
    I would like to add with both the evo & the Renegade kit
    It has the benefit of air cooling the fuel as it is hitting the underside of the tank!
  4. #34
    Aug 2011
    Essex UK
    So what kit do you think is better Micah?
    The Open renegade or Sealed Evo kit?
    Just curious
  5. #35
    apriliaforum expert FTM's Avatar
    Aug 2005
    Portsmouth Uk
    There is an old thread somewhere on the Gen 1 Tuono section that shows a power gain of about 2hp by changing the Aprilia airducts for simple 90 degree rubber tubes pushed into the frame. The Aprilia airducts must be causing turbulance in the airbox.
    FUCK THE MAGS Nuke the whales!
    I see to recall that the ORIGINAL Tuono was around £18000 new......
    Only 200 of them made (and yours ain't one of them FTM.....) worldwide.
    The Male Whale
  6. #36
    Aug 2005
    Portsmouth Uk
    I have noticed on some of the renegade type air intakes the filter hits the underside of the tank so I'd guess about 20% of the available surface of the filter is lost.
    The Male Whale
  7. #37
    Quote Originally Posted by Toastrider View Post
    If the air is cooling the fuel, isn't the fuel heating the air?
  8. #38
    I guess it might have been missed earlier, the best all around airbox for my Gen1's was in both instances the stock airbox and filter with a 1999 spec intake boot attached to bottom of airbox. The best airbox for the Gen2 I help with as a track bike...stock airbox and filter.
    The best airbox I ever tested on my Gen1 was the MSS for true gains, nothing up top, a small loss actually but substantial midrange gains. It was a pain int he ass to take on and off though so back to stock I went.
    I would never use a Renegade style pod kit on any modern bike, the entire line of thinking that a flat plate with a big foam pod filter over the top of it is going to beat the R&D of any Japanese or European factory is somewhat misguided.
    Micah Shoemaker
    699 W. San Antonio
    830-626-3966
    micah@af1racing.com
  9. #39
    Aug 2011
    Essex UK
    Re airkit
    I guess the factory have to abide to noise regs etc.
    Was the stock box on a stock bike?
    I ask because I refitted my stck air box and I lost lots of midrange ?
    I have a Gabro chip and Dual link collector
    So it makes sense the bike requires more air
  10. #40
    Aug 2011
    Essex UK
    Re
    What's the issue with a pod filter over the stacks
    As opposed to standard location
  11. #41
    Jul 2011
    home
    If your worried about heating your fuel, cover the bottom of the tank in reflective alloy tape. Not to stir the pot even more but arent these bikes quick enough? The right gearing is bound to make your motor feel quicker than spending all kinds of money on air boxes. Carbon mss is nice for bling factor, I made my own evo style out of a spare air box lid and some heavy neoprene rubber for a gasket, it's cheap , nasty and crude but it worked, noisy as heck when you wind it open low down but never dyno'd so don't even know if it's better or worse. More to the point and to tie in with the power commander vs chip thread, unless you are prepared to spend a fortune on fine tuning so your motor is running 100% and fuelling is bang on, what difference is and air box going to make on its own?
  12. #42
    apriliaforum expert vonDutch's Avatar
    Sep 2008
    Netherlands
    There is more to the design of an intake channel then meets the eye, to say the least. The mass of air, the temperature, the frequency of a resonance, the length if the intake channel or the diameter, all can work in your advantage at one point and work against you in the other.
    I take the closed characteristics of the OEM intake setup, together with the length of it works in your advantage, when it comes to performance. I like the open setup for looks and sound. Each his own...
  13. #43
    The volume of an airbox when it comes to Hemlotz resonance is calcualted as the area/volume between the intake valves and back side of the air filter if equipped with a filter. Putting a filter right over the tops of the intake stacks makes a pretty small volume of air...which is resonant only at very low rpm, more volume, more rpm for beneficial resonance.
    Micah Shoemaker
    699 W. San Antonio
    830-626-3966
    micah@af1racing.com
  14. #44
    apriliaforum expert PumpinIron's Avatar
    Jan 2011
    Portland, Oregon
    Quote Originally Posted by planter87 View Post
    My thoughts exactly! A few horsepower here or there means nothing to any of us street riders. Heck, even on the track I doubt 99% of the people on this forum can actually push this bike to the limits.
    However, some people have the money to blow, and for a lot of us tinkering with these bikes is just another hobby =]
    2003 Aprilia RSV Mille R
    Akrapovic 2-2 Headers, Ladybird Titanium Mufflers, 57mm Throttle Bodies, Derestricted Airbox Inlet, Renegade Airbox, Edwards EPROM, 16/43 Supersprox Stealth Sprockets, EK MVXZ 520 Gold Chain, Brembo RCS 19 Brake Master Cylinder, Brembo RCS 16 Clutch Master Cylinder, Edwards Triple Clamp, Integrated LED Taillight, Zero Gravity SR Light Smoke Windscreen, Sargent Seat, Bridgestone Battlax BT-003 Tires, and more to come!
  15. #45
    I mention bore kits and heads earlier for this very reason, if you really are hunting real power gains that will make you go "no shit" in your helmet...internal work is required, or nitrous, or boost...bolt on's are not going to do it.
    Micah Shoemaker
    699 W. San Antonio
    830-626-3966
    micah@af1racing.com
  1. 54mm T.B.'s with "Hooked Air Box Kit" in the for sale section
    By angelo1000r in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 12-07-2009, 08:07 AM
  2. Who does the Best Big Horsepower Kit for the Mille R
    By 1SPODE-MILLE-R in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 05-16-2005, 06:49 PM
  3. Air-box Mod for sale! Cheap!
    By rippinrubber in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 08-29-2004, 04:47 PM
  4. More fuel for the Mille swingarm/shock debate
    By falcofra in forum SL1000 Falco Forum (all years)
    Last Post: 12-02-2003, 04:19 PM
  5. Bar Risers for the Mille.......
    By vpr80 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-26-2003, 02:01 PM
