Results 1 to 15 of 15
Thread: Questions for the pros...
    apriliaforum Member nexlvlsh!t's Avatar
    May 2012
    Vancouver
    Question Questions for the pros...
    Question 1:
    I have replaced the 3 degree key. Upon removing the old one i noticed a groove (a) and also obviously (B). There is also a groove on the magnetic flywheel. How important is it that 3 these things line up or does it even matter? I lined up the actual key with the cover that goes over and all seems well. Is that groove represented by A (arrow) just for decor???
    Question 2: I am replacing the reed valves and notice 2 bolts are HEX-PINS (tamper proof?)and 2 are normal. Is this Name:  FM8EPRXFQJZNR6R.TINY.jpg
Size:  882 Bytes just http://www.megapro.net/products/drivers/tamperproof/ ??
    2007 SR50 Factory
    Reed valve -MALOSSI MHR VL14 Aprilia 50cc Morini - carbon fiber
    Malossi multivar 2000 Morini
    Porter Cable Water Trap
    Woodruff key -TOP PERFORMANCES 3x5mm- Morini 50cc 2-stroke
    Exhaust -LEOVINCE ZX-R- DiTech LC (Morini) Installed 06/01/2012
    Stickers Removed
    Derestriction ECU map 2.8.2
    HGT Gen III Fuel Regulator
    LED Headlights
    Custom License Plate LEDS
    Malossi Air Filter
    Malossi Belt
    Dr Pulley 7.0g Sliders
    apriliaforum expert Alexandar's Avatar
    May 2011
    Skopje, Macedonia
    The 3 things to be lined up doesent matter because the fly wheel cover the one with the magnets has grove inside so you can put it correctly in a way that the space"grove" inside is for the wodruff key also it will not fit on the crank if its not aligned correctly since the wodruff key wont allow it to fit also on the cover with the magnets on the outside there are i think 24 pins and on one place is clear without the pin and that position gives the timing to the sensor "ignition"
    the important thing is to put the key correctly as it is on the picture
    SR DiTech Piaggio c361 2005
    Polini Kit 70cc
    Polini Bowl
    Malossi Multivar 2000
    Original Piaggio Contra Spring
    Rollers Malossi HT 7.5 grams
    Malossi Special Belt
    Malossi Oil 7.3 & Agip City 2T
    Malossi Gears HTQ 14/39
    Gianelli Reverse
    Air Diffuser 20mm
    Clutch Stage6 Torque Control MKII
    RMS Crank
    Woodruff Key 3degrees
    Malossi Air Filter
    Polini Carbon Reeds 0.35
    Water Trap
    Fuel Pump Mod
    Ecu Derestricted version 2.8.0
    Spark Plug NGK ZMR7AP
    Sava MC 29 Sporty 3+
    Lights Philips Master LED spot LV 10wx2
    Brembo brake pads
    May 2011
    Skopje, Macedonia
    for the bolts you need key number T30 also replace them as they are pain in the ass since the metal they are built is very fragile so in the future you could remove them more easily
    Polini Kit 70cc
    Polini Bowl
    Gianelli Reverse
    Air Diffuser 20mm
    RMS Crank
    Malossi Air Filter
    Water Trap
    Fuel Pump Mod
    Brembo brake pads
    apriliaforum expert Cool77's Avatar
    Drummondville,Quebec
    By the meantime, you can break the tiny pin with a punch, using a back and forth movement. then, you can use a normal bit. And thanks snugg for that little trick
    Aprilia SR Factory 50 2006 IE Morini Engine type
    13 500KM
    MAX Speed after rod in 92KM/H flat no wind, 104 KM/H tuck
    Malossi BBK + Full Circle Crank since 10 287KM
    Stock Gears
    ECU : Malossi
    Mod : Leo Vince ZX-R Pipe flat black ceramic coated - HGT regulator Gen III - Malossi multivar 2000 - 9.0gr Dr. Pulley rollers - Malossi delta clutch small white spring big white spring w/o tc - Malossi belt - Malossi red foam air filter - ZMR7AP plug - Water trap - Malossi Reed valve VL-12 - Buzzetti side stand - YSS Rear shock.
    Moderator (ADSUM) Grenadiers's Avatar
    Sep 2008
    Nice weather AT LAST! Winnipeg, MB
    Yup to the above... The Tamper Proof Torx is no longer needed. Break off the pin and either replace the tamper proof Torx with a regular one. Or continue to use that one. It will depend on how much of that pin you are able to break off. If memory serves me it's a M6 X 20. I used Stainless Steel to add a bit of "bling"...
    Anger is an ugly Mistress…
    06 SR50 (Morini)/AIRSAL 70CC BBK/NGK BR9EIX/My Top Speed-117KPH (GPS)!!
    Rear Rack & Top Case/Buzzetti Side stand/Aprilia Racing Shock W/STR8 65mmRiser/HGT Stretch Kit
    HGT PFI Kit/Malossi MHR Team II Pipe/All Polished Water Pump
    Black HGT Gen 3 Fuel Regulator/Stebel Magnum Horn/Glowshift Elite Gauge
    BING 26mm TBA/BGM Pro Reed Block & Pod Filter
    Polished Aluminum Varo W/Kick start & Pod Filter/HEL Brake Lines
    HGT Red Brake Levers/LED bulbs/BGM LED Tail Light
    Malossi Delta Clutch w/Blue springs/Red Contra spring & TC/MHR Full Circle Crank
    Malossi 15/40 Primary Gears & Multivar w/4.4gr Dr. Pulley Sliders/Kevlar Belt
    Michelin Pilot Sport 140/60 Rear tire w/Dyna Beads & TPMS Sensor
    apriliaforum expert NoNameForEver's Avatar
    Sep 2008
    Northern Europe
    Just so this is clear, don't do this if scooter is still under warranty(break the pins without replacing the bolts like-for-like)
    Glyptocephalus cynoglossus lover
    Quest for no 3D glasses
    Sep 2008
    This is a Morini... the Warranty is long over, unless he purchased it used from a dealer with some sort of after-market warranty. But yes, breaking the pin while the bike is still under warranty could void it...
    apriliaforum expert Rosscofat's Avatar
    Vancouver BC
    if I knew they had hex pins.. I let you borrow my tool. I have the one to remove them.
    May 2012
    Vancouver
    Thanks! I'll head to home depot and see if I can locate a punch or the correct bit.
    2007 SR50 Factory
    Stickers Removed
    LED Headlights
    Malossi Air Filter
    Malossi Belt
    Sep 2008
    Northern Europe
    Vancouver BC
    You can pick up the right bits at Lord's or napa its a screw driver style with bits. Red handle
    May 2012
    Vancouver
    I did the snugg technique. Stuck a very small flat head in there and pounded it with a hammer until it snapped. Several colorful phrases were mumbled in the garage from time to time but in the end the bolt got pwned and out came the old reed valve. The 3 degree key went in relatively smooth. Results were better mid range, a tiny bit of top end lost and more power on the hills.
    2007 SR50 Factory
    Stickers Removed
    LED Headlights
    Malossi Air Filter
    Malossi Belt
    Vancouver BC
    Good stuff.
    May 2011
    norway
    Just be careful jo you bend the pin too far to one side, so you cant get hold of it. i had to take of the seat and box assy. and hammer a bit into the screw
    Stock Aprilia Ditech 03 model(Morini)
    Derestricted variator
    6,6g rollers
    molossi powerfilter
    NGK ZMR7AP
    May 2012
    Vancouver
    Quote Originally Posted by xavi0n View Post
    You're right, the pins have a tendency to bend easily making the removal process quite difficult.
    2007 SR50 Factory
    Stickers Removed
    LED Headlights
    Malossi Air Filter
    Malossi Belt
  1. Preparing to do a reseal - Quick Question for the pros..
    By motoracer897 in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 03-11-2010, 09:54 AM
  2. Another Front Radial Master Question for the '04 Factory Guys
    By Ted in Evanston in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 03-29-2004, 07:18 AM
  3. Question for the Jersey Boyz
    By duganc in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-07-2004, 09:26 PM
  4. Wiring colour question for the collective
    By Thunder Factory in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 10-10-2003, 01:24 AM
  5. Non Aprilia Question For the UK guys. 2003 TZR50.
    By RS75 53 in forum RS50 Technical
    Last Post: 05-02-2003, 10:04 AM
