Results 1 to 8 of 8
Thread: Fuel tank rubbing triple clamp
    Mar 2012
    san francisco
    Question Fuel tank rubbing triple clamp
    Not sure what the cause of this is. Maybe head bearing installed wrong?
    The tank is installed all the way back:
    Here you can see the rubbing:
    The rubber head/triple bushing is getting squished by the gas tank:
    The bearing/triple seem to be pushed back:
    apriliaforum prov-nov Sibhod's Avatar
    Mar 2012
    Northern California, Silicon Valley
    My tank has done this too. Our tanks expand due to ethanol in gasoline I believe but there may be other contributing factors. Search on it, I have read other threads and there are some suggested solutions but I don't remember what they are now.
    2004 RSV 1000 Factory- Yes!!! Living the Dream!!
    1998 Honda VFR800 (Gone- Destroyed by Hit-and-run drunk driver in 2011. Caught & Prosecuted!)
    1992 Kawasaki EX500 (Gone)
    1992 Suzuki Bandit 400 (Gone)
    1982 Yamaha Virago 920 (Gone)
    1982 Yamaha Maxim 650 (Gone)
    apriliaforum Junkie madbrad16's Avatar
    Oct 2010
    Rexburg, ID USA
    Mine does the same thing on one of my RSVR's and its fairly frustrating but I've never found a cure for that. I've read about the ethanol tank expansion thing and that's probably the cause.
    Current stable:
    2004 RSV 1000 R black
    Previous:
    2008 RSV 1000 R silver... Sold
    1981 Honda Goldwing(not a joke!)... Sold
    2004 RSV 1000 R white... Sold
    2000 RSV Mille... Sold
    2004 RSV 1000 R Factory... Parted out
    Kiss french... Ride Italian.
    Mar 2012
    san francisco
    When trying to reinstall I could not get the tank short enough to get the bolts in by the triple. The only solution I found was to grind the seat hook off of the rear bracket and flip it upside down, pulling the tank down and back further. Unfortunately there is no solution to this problem, unless I get a new tank (in bol d'or).
    Jun 2006
    Columbus, GA
    Same problem on my Futura. Not on my RSV though, but it has had an ethanol treatment added since day one though.
    __________________
    ____@FoxFader_____
    Current Swag - '01 Futura in Silver, Acumen DGVPainted W-screenPazzo Knock-offs.
    Jesus, family, me. Psalm 121 - Red Pill Mille Clip - Delkevic Sound Clip
    Past Swags: 09 RSV 1000R, 06 GSXR 1000 SF, 02 Bandit 1200 N, 03 RSV 1000, 05 Katana 600, 98 VLX 600, 00 GSXR 750, 01 Futura 1000, 02 Bandit 1200S, 83 V65 Magna, 91 Nighthawk 750, 9? 700 Honda, 93 GSXR 750wp, 91 Katana 600, 78 KZ400, 82 CB450 Custom
    HF152, 10-26954
    HF564,
    __________________
    __________________
    Mar 2007
    Palos Verdes Est. SoCal
    Wink tank?
    j8food.......
    pay attention, your frame shrank......
    just think how bad it would be if the front mounting holes where centered
    Noel-theknurl
    The Forum Curmudgeon
    I'm not PC either
    ph. 310-540-4823 PST, GMT -8
    Stroudsburg, PA
    If left to dry out for a few months in a hot dry place with the fuel pump and gas cap removed your tank should shrink back to close to its original size. The ethanol in E10 gas absorbs water out of the air and then the PA6 nylon gas tank absorbs the water and swells. When the tank dries out it will shrink back to its original size or close to it. Several people on the forum have reported good results sealing the insides of their tanks with Caswells tank epoxy to prevent it from swelling again after it has shrunk back down.
    Mar 2012
    san francisco
    Awesome, thanks for the reply Dan. I'm ordering a beat up tank off ebay to run until mine shrinks. Unfortunately san Francisco is not dry or sunny. Now I just need some matching paint...
  1. tank rubbing top triple
    By valileo in forum RS250
    Last Post: 06-21-2007, 06:38 PM
  2. Replies: 6
    Last Post: 09-10-2006, 05:05 PM
  3. Replies: 0
    Last Post: 08-08-2006, 02:01 AM
  4. Edwards Rep triple clamp - HOW MUCH?!?!
    By cplus in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-07-2003, 08:57 AM
  5. need torque settings for triple clamp bolts.....
    By RinOz in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-02-2003, 01:30 AM
