Results 1 to 13 of 13
Thread: Mods Complete
    apriliaforum expert shannon's Avatar
    Aug 2005
    Knoxville,TN
    Mods Complete
    Just completed a number of updates: Added showa forks, rotors, calipers, brembo clutch master and brembo brake master all taken from my 2004 mille along with custom ss braided lines, MPL clutch slave, fork sliders & driven knock off grips. Wiring mod done per bossbob. Other than a new rear shock I can't think of much else to be done.
    Current:
    02' Futura: Staintunes, H-pipe, Firebolter air kit, Corbin w/backrest, Mille forks, mille rotors, mille calipers, ss braided brake & clutch lines, MPL clutch slave cylinder, brembo radial master cylinders, license plate bracket chop, charcoal cannister removed, fork sliders, R&G frame sliders, throttlemeister, smoke windscreen, air box derestricted, mille air boot, stomp grip tank pads, anodized gas cap bolts, Ford starter relay, Ballistics lithium battery, helmet lock, carbon rear mud guard, Marsee corona tank bag, filler cap mod
    04' RSVR Track - In part out mode
    May 2012
    Chattanooga, TN
    Looks good, Shannon - you've done a heck of alot of work.
    Now with all that trick stuff, I'll be ashamed to ride my box
    stocker next to yours. What kind of mirrors/turn signals are
    those, Gixxer?
    Doug
    Aug 2005
    Knoxville,TN
    Gixxer, installed by the previous owner. You can't see anything out of these either.
    Current:
    apriliaforum Junkie terry mc's Avatar
    Mar 2010
    Phoenix
    Nice work Shannon,
    Did you install the bar ends? If so how do you also have the internal weights?
    If you have installed them, how much difference has it made on vibration. I ask as I have HAVS (hand, arm, vibration syndrome and no I am not making that up) it is a condition from years of vibration from tools and motorcycles that cause numbness and can be a permanent condition. I have it under control, and the Futura is a lot better than previous bikes, however every little bit helps.
    I guess I need to get busy with the mods to try and keep up.
    Terry
    Too little time, Too many Bikes!
    01 FUTURA
    MODS LIST;
    RaceTech 25mm cartridges in Mille Forks, Ohlins rear shock with custom valving,
    320mm Rotors, Brembo 4 pad calipers, SS brake lines, Ferodo ST front pads, Radial master cylinders (both),
    mille air boot,AF1 H-pipe, Staintune Exhaust,
    Mosfet RR, rectifier wiring mods done, metal fuel disconnect done,
    Aux relay installed to run seperate wiring for accessories (garmin, escort 9500, and an amp with volume control for earbuds)
    CBR1000RR mirrors,
    01 MILLE 'R (trackbike)
    00 ZRX1100 (WIFES BIKE)
    78 RD400 (WIFES BIKE)
    IBA MEMBER #48709
    Aug 2005
    Knoxville,TN
    Hey Terry, the throttlemeister was installed by the previous owner. That being said I can't give you a comparison but the current set up seems very stable to me. However, I'm not nearly as sensitive to the bars as you. Tomorrow if I have time I'll see how difficult they are to get off and see what's inside the bars. Maybe I can get a picture.
    Current:
    Mar 2010
    Phoenix
    Thanks Shannon,
    If it is difficult don't worry about it. To me the stock Futura is smoother than I expected, but like I said more is better in this case.
    Terry
    01 FUTURA
    MODS LIST;
    CBR1000RR mirrors,
    IBA MEMBER #48709
    Aug 2005
    Knoxville,TN
    Here ya go Terry. After removing the throttlemeister you are left with a threaded insert for the handlebar. However, the handlebar has nothing inside. Maybe due to the weight of the 2 parts they act as anti vibration and no internals are needed.
    Current:
    apriliaforum Junkie threeviews48's Avatar
    Jul 2010
    UK
    Quote Originally Posted by shannon View Post
    Hi
    Do you know what model Gixxer, are they an easy swap?
    May 2012
    Chattanooga, TN
    Quote Originally Posted by threeviews48 View Post
    Hi
    Try this:
    http://www.amazon.com/Suzuki-Mirror-.../dp/B005AITM9C
    Can't confirm the accuracy of the Amazon ad, but according to it, integrated mirror/turn signal units are available for the following GSXR models:
    '06-'10 GSXR 600
    '06-'10 GSXR 750
    '05-'08 GSXR 1000
    Here's a link on the gixxer site for retrofitting integrated mirror/turn signals to an earlier model gixxer (scroll down to read). It's unlikely the Futura installation would be the same, but the gixxer post at least gives you a general idea as to what's involved. The Futura wiring is already in place so the electrical connection should be easy, but the base plate and mirror attachment might require some additional creativity. I've seen this mod on other Futuras so maybe someone here has already done it.
    http://www.gixxer.com/forums/showthread.php?t=322151
    Doug
    Aug 2005
    Knoxville,TN
    I have no idea what model as one of the previous owners installed them. I would say install is fairly straight forward with the exception of having to splice the electrical connections.
    Current:
    Mar 2010
    Phoenix
    Thanks again Shannon for the info,
    3views,
    Yes they are fairly straight forward with a few small caveats
    1 the fairing support needs the holes slotted slightly as the bolt pattern is not an exact match.
    2 if you do not make angled shims they tend to look a little droopy as the angle of the mirrors are not the same as stock.
    3 I do not know about Shannons but the base plate on mine did not cover the center hole for the turn signal wiring completely.
    4 you will need to run an resister in series with them or find a lower wattage amber lamp as the stock lamp is a higher wattage than the stock turn signals and it will drive you flasher relay nuts.
    All that said they work better than the stock ones in my opinion, and look better. You can find a thousand brands of the same mirror on Ebay and they are cheap. Just beware as the quality is not fantastic.
    I will be looking at the CBR1000 mirrors as they are similar but look to have a better angle for matching up to the fairing.
    Terry
    01 FUTURA
    MODS LIST;
    CBR1000RR mirrors,
    IBA MEMBER #48709
    Mar 2010
    Phoenix
    Now you did it Shannon,
    You had to bring up the mods and an Ohlins rear shock became available on Ebay.
    After just finishing with the Ohlins fork valves I just had to get the shock, and they accepted my offer.
    Terry
    01 FUTURA
    MODS LIST;
    CBR1000RR mirrors,
    IBA MEMBER #48709
    Aug 2005
    Knoxville,TN
    Let me know how the install on that shock goes. I assume you will be following The Fixer's install:
    http://www.apriliaforum.com/forums/s...ll-Linkage-Mod
    Current:
  1. Suspension/brake mods completed today
    By Apriliain in forum RST1000 Futura (all years)
    Last Post: 05-06-2011, 01:32 AM
  2. 1st round of Mods complete
    By Bayou in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 04-12-2011, 05:27 PM
  3. Strada Stage 1 mods complete...
    By Gravityfreak in forum 2006+ Pegaso Trail / Strada / Factory
    Last Post: 06-11-2008, 06:06 PM
  4. battery mod complete
    By vil_guy in forum RST1000 Futura (all years)
    Last Post: 04-13-2008, 11:14 AM
  5. Wiring Mod COmpleted--Intresting Results!!
    By Firebolter in forum SL1000 Falco Forum (all years)
    Last Post: 09-03-2005, 11:05 PM
