Results 16 to 18 of 18
Thread: besides the pod style air filters what would you use
    Jun 2011
    ilion
    you are definitly right on that being a noisy set up with just the cone air filter
    apriliaforum Junkie nathan k's Avatar
    May 2012
    England, New forest
    Quote Originally Posted by RS_Patrick View Post
    Airbox drilled is a verry bad idea... you need to mod it with an extra intake tube, if you just drill holes you create vortexes in the airbox wich can in the worst case suck air away from the carb stalling the airflow and engine.
    For Carbs up to 21mm its not needed, but it makes a nice deep (not to loud) sound even with a stock carb.
    Not in the side of the air box, where the original intake holes are i simply added a few more, had no problems and it's a 21mm carb so i can claim i need it
    Nov 2005
    Quote Originally Posted by nathan k View Post
    It doesnt matter where you drill them, its the fact that there just holes and not tubes, it will actualy reduce airflow instead of increasing it as you get a vortex from the edges of the hole, Airboxes all got tubilar intakes to "straighten" the airflow as it comes into the airbox.
    And like i said, it makes for a much nicer, deeper/heavier sound with out becomming anoyingly louder, and wen you drive it normaly you wont atrackt the atencion of the cops because the bike runs better at all throttle positions and doesnt make a loud/weird noise at half throttle etc.
  1. oil filters - What are you using?
    By GPM in forum SL1000 Falco Forum (all years)
    Last Post: 03-30-2011, 10:09 AM
  2. SILMOTO pipe, AF1 AIR FILTER..what is the map to go with?
    By kingkauf in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 06-11-2010, 02:45 PM
  3. what would you use to clean a chain??
    By bourney2007 in forum General Motorcycle Talk
    Last Post: 03-04-2009, 03:01 PM
  4. K&N air filter what do you think?
    By hagasn in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 01-13-2006, 07:31 PM
  5. Over the TB's air filter...
    By TampaMille in forum General Motorcycle Talk
    Last Post: 01-14-2005, 04:31 PM
