Results 1 to 15 of 18
Thread: besides the pod style air filters what would you use
    Jun 2011
    ilion
    Upgrading the carb and the old pod filter wont work so where should I go for my next air filter , I am not going to even try and get a stock airbox parts are to hard to get in the USA so looking for other option have looked at other types of pod filters that look like they may be better.Name:  malossi_e13.gif
    apriliaforum Junkie camb00's Avatar
    Jul 2011
    Netherlands
    If you were going to use one, make sure you get a dual density foam filter they are better.
    Twin air filters are good
    apriliaforum Junkie RonneBear's Avatar
    May 2011
    Queensland, Australia
    Ram Air
    Sep 2011
    warrington uk
    use oil like this on it and plenty of it
    http://www.adrenalin-pedstop.co.uk/p..._kit-4991.aspx
    Engine Always Screaming!
    Nov 2005
    Netherlands
    Go-Kart (style) airbox, works great.
    Jun 2011
    ilion
    tried looking up gocart style didnt come up with much alot of the same pod style filters. one air box i found was oval shaped with 2 air intakes but that was realy it
    Nov 2005
    Netherlands
    Look at a Go-Kart parts site.
    First thing i get wen i type in google: Go-Kart Airbox is this site in the USA: http://www.spkart.com/category.aspx?categoryID=109
    Jun 2011
    ilion
    I looked at those on that web site way to expensive but there was another store I found that had on for a 100cc motor 2 inlets. would i have to buy the filers though or do they normally come with the whole set up
    Nov 2005
    Netherlands
    I dont know, i know K&N usualy doesnt suplie filters with there airboxes, and there are Go-Kart airboxes that are just a airbox with nothing in it, just ment to reduce the intake noise from an open carb.
    Jun 2011
    ilion
    so would I run the pod filter inside the air box or should I go with a different set up
    Nov 2005
    Netherlands
    Its better to get an Airbox with a Filter already in it, unless the filter and podfilter where ment/designed to go together.
    Aug 2011
    Oregon
    Yes you can still order the OEM airbox. It's around $100 though. I asked 1-2 months ago at the local Aprilia dealer and I'm in the USA also.
    apriliaforum expert apriliamandan's Avatar
    Jan 2012
    England (Cambridgeshire)
    Ram air are well known and used alot
    apriliaforum Junkie nathan k's Avatar
    May 2012
    England, New forest
    In the summer K&N, oiled every week plus i don't use it in the rain. Winter or when i go greenlaning, back to drilled out airbox.
    Nov 2005
    Netherlands
    Airbox drilled is a verry bad idea... you need to mod it with an extra intake tube, if you just drill holes you create vortexes in the airbox wich can in the worst case suck air away from the carb stalling the airflow and engine.
    For Carbs up to 21mm its not needed, but it makes a nice deep (not to loud) sound even with a stock carb.
  1. oil filters - What are you using?
    By GPM in forum SL1000 Falco Forum (all years)
    Last Post: 03-30-2011, 10:09 AM
  2. SILMOTO pipe, AF1 AIR FILTER..what is the map to go with?
    By kingkauf in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 06-11-2010, 02:45 PM
  3. what would you use to clean a chain??
    By bourney2007 in forum General Motorcycle Talk
    Last Post: 03-04-2009, 03:01 PM
  4. K&N air filter what do you think?
    By hagasn in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 01-13-2006, 07:31 PM
  5. Over the TB's air filter...
    By TampaMille in forum General Motorcycle Talk
    Last Post: 01-14-2005, 04:31 PM
