In Canada, I just bought two NGK ZMR7AP plugs (part number 6914) from Club Plug (based in Laval, QC of all places! who knew?). They were $16.42 each shipping included (it was the included shipping that hooked me!).
Cheers,
Cheers,
2007 SR 50 Factory Ditech (Morini) 9000 kmsBuzzetti side stand 03/18/12PIAA 'Slim Line' Sports Horn 05/21/2012Porter Cable water trap 06/19/12ECU completely derestricted ver 2.8.0 (YES! Thanks HGT 08/10/12)LV ZX-R 09/10/12Motul Scooter Power 2T oil (100% synthetic)NGK ZMR7AP spark plug, indexed, gapped to .030Malossi Multivar 2000 w. 7 gm rollers, Malossi Special Belt, White contrast spring @ 8000 km 11/12/128mm Mirror Riser Extender 05/12/2013Michelin Power Pure tires @ 9000 km 05/18/201390 kph on slight down hillAlso in the garage: 1987 BMW R80
Good call Jimyou told me about that place and forgot .
2009 white sr 50 factory
michelin pilot tires
athena kevlar drive belt
95km/h on flat
88psi of compression
deristricted ecu
3 degree advance key
Leovince ZX-R
RED clutch springs
stage 6 rt variator
8 gram rollers
medium top performance transmission spring
+/- 15000 km
digidash says 419000 but was estimated to be at 10,000 last year
yup i checked on their site but i can't find their adress
95km/h on flat
deristricted ecu
Leovince ZX-R
RED clutch springs
stage 6 rt variator
8 gram rollers
+/- 15000 km
so i changed my spark plug couldn't find any zmr7ap so for the moment i baught a cpr8eix (or something along those lines i don't remember the code exactly) while changing my spark plug i looked at the old one and it was a cpr8eix too .... now i will add a water trap and change my 2t oil that smells like strawberry that the dealer gave me when i baught my scooter and i will be going towards agip 2t oil and change my belt ... because i noticed that on the sides it was getting bretty worn and i do not want it to break and dammage anything else
95km/h on flat
deristricted ecu
Leovince ZX-R
RED clutch springs
stage 6 rt variator
8 gram rollers
+/- 15000 km
till your belt breaks in. it will feel diff and feel like it has more bottom end power.
yes i noticed that ... last year i got a new belt and noticed that i had more accelerartion than my friend who has a 70cc kit on his yamaha ... but it doesn't take long to break in na new belt my last one i finished breaking it in, in three days
95km/h on flat
deristricted ecu
Leovince ZX-R
RED clutch springs
stage 6 rt variator
8 gram rollers
+/- 15000 km
usually its about 200-300kms...
95km/h on flat
deristricted ecu
Leovince ZX-R
RED clutch springs
stage 6 rt variator
8 gram rollers
+/- 15000 km
Belt break in. Mine took about 250km before it felt normal again
yeah ... thats about the amount of time it took for mine
95km/h on flat
deristricted ecu
Leovince ZX-R
RED clutch springs
stage 6 rt variator
8 gram rollers
+/- 15000 km
how do you adjust the ''gap'' of a spark plug ... do you buy it gapped or do you need a tool to gap it .... and what is the difference between a gaped plug and an ungapped plug
95km/h on flat
deristricted ecu
Leovince ZX-R
RED clutch springs
stage 6 rt variator
8 gram rollers
+/- 15000 km
This is the tool you would use..
