Results 1 to 9 of 9
Thread: Low fuel light.
    Jul 2009
    UK
    Low fuel light.
    Anyone know when the indicator light is supposed to kick in? It always seems strange that I have never seen it come on. And as mine has a reserve position on the fuel tap, it almost seems pointless. When does yours come on?
    Chicago, US
    There is a electrical connector on the left side under the fuel tank to the front. Look for black cable/wire with black connector.
    It might be stuck/hidden under the tank.
    Jul 2009
    UK
    Quote Originally Posted by stisma View Post
    I know where it is, and I know that the light works. I'm guessing that I may have a problem with the sensor itself though. But I wanted to know when the light should come on? While on main or in reserve?
    Chicago, US
    When the reserve light comes ON there is about 3-5 ltr of fuel remaining
    and then we switch to reserve position. The light will still be ON.
    (the reserve light will come ON regardless of the fuel petcock/tap position,
    if the fuel level reaches certain low level)
    Jul 2009
    UK
    That's exactly the info I wanted. My suspicion is that the sensor in the tank is up the duff. Will try siphoning some fuel and see if the light comes on.
    apriliaforum Junkie SJL's Avatar
    Jul 2011
    UK
    Quote Originally Posted by robg View Post
    An easier way would be to turn petcock off, remove fuel line from petcock, position old clean glass jar under petcock and turn petcock back on to "On" rather than "Res", then when it stops leaking into glass jar replace fuel line onto petcock, turn to "Res" and start bike.
    The light should come on straight away at that point.
    Cheers,
    Ste
    I am not an expert, please make your own judgement on diagnosis prior to doing anything drastic! I cannot accept any responsibilty for any work done on suggestions from me! If you are unsure, please contact your local garage.
    apriliaforum Member VSU21's Avatar
    Apr 2007
    Sydney Australia
    Hi Rob,
    I think you have got the point, but to confirm the fuel light on my 2000 cube will turn on while swithced to main tank and stay on once the fuel cock has been swung to reserve.
    The fuel light goes out once I've filled up independant of where the fuel cock sits, so yeah, no switch on the fuel cock, it's in the tank somewhere I suppose.
    The 21 litre tank will use a bit more than 15 litres before the light comes on, I beleive I need to use 16 litres to be on reserve. I normally switch it over to reserve when the light comes on, and fuel up the next morning. Never run out or stalled.
    So if you find an adjustment or something, thsi is an ideal way to set it up.
    Cheers,
    VSU21
    Apr 2007
    Sydney Australia
    Yep there's a fuel level sensor in the tank.
    Workshop manual link below.
    https://docs.google.com/file/d/0B_0G...DI1/edit?pli=1
    Cheers from Australia
    Chicago, US
    And here is the sensor itself in daylight.
  1. "Low Fuel Light"
    By Ape Man 2007 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 06-18-2007, 09:13 PM
  2. Blinking low fuel light? WTF?
    By PixelPusher in forum RST1000 Futura (all years)
    Last Post: 01-16-2007, 09:40 AM
  3. Low Fuel light? no worky!
    By uberchicken in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 05-13-2006, 04:37 AM
  4. Low fuel Light too soon
    By DockingPilot in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 03-24-2004, 09:15 AM
  5. low fuel light "stuck" on
    By vtrandall in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 01-20-2004, 11:09 PM
