Results 1 to 3 of 3
Thread: Malossi multivar problem?
    Feb 2012
    Glasgow (Scotland)
    Just finished fitting a malossi multivar, LeoVince zx, Leovince red clutch springs and the 7.2g rollers with the multivar (iv tryed to make a sig with my spec but it hasnt worked)
    Its seems to rev really high and the acceleration seems to be worse and the top speed hasnt improved also. There is a really bad buzzing from the cvt cover also
    anyone got any ideas
    2005 Sr50 R
    LeoVince Zx
    LeoVince red springs
    Malossi multivar
    7.2g rollers
    Stage6 rev counter
    Malossi white contra
    Banned Snugg's Avatar
    Aug 2007
    Aurora, CO
    Something could be loose.
    Did you install a new belt as well?
    What do you mean by rev really high?
    What are your RPM's at when the clutch engages?
    What are your RPM's at when you are accelerating at WOT?
    What are your RPM's at when at full speed?
    Feb 2012
    Glasgow (Scotland)
    I cant tell what rpm since its only the speed it shows, iv just noticed iv left out the thick black metal washer, but the instructions show 2 different ways to put it on. One way shows the it is the very first thing to go on then then the multivar as if the thick washer is spacing it out from the back of the cvt housing and thhe other instuction says that it was the last thing to go on before the nut??
    2005 Sr50 R
    LeoVince Zx
    Malossi multivar
    7.2g rollers
    Stage6 rev counter
  1. Malossi Multivar Variator
    By the-chauffeur in forum Aprilia and Piaggio 500cc
    Last Post: 10-25-2007, 04:53 PM
  2. What rollers come with Malossi MultiVar?
    By TiminIndy in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 05-05-2005, 10:40 PM
  3. Malossi Multivar vs Tweaked Stock Unit
    By MultiplexMan in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 01-18-2005, 02:12 AM
  4. Malossi Multivar and extra Roller Weights!!!
    By baamonde1 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-09-2003, 10:03 AM
  5. Malossi Multivar for sale...
    Last Post: 05-03-2003, 05:15 PM
