Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: Fuel sensor.
  1. #31
    apriliaforum expert Twinz's Avatar
    Aug 2008
    Montpelier, VT
    Today, I went after the potting compound from the inside (pump side) of the harness. After carefully chipping away with a small screwdriver, the green pump wire popped out. I pried some more around the other wires, which seemed like they were firmly attached. I screwed-up with my pencil soldering iron by melting a little of the plastic wire harness housing, but I'm sure I can still cover everything with the Caswell epoxy. One question...the harness has an o-ring seal and the two screws holding the harness are tight. Does anyone know if any sealant is necessary on that o-ring (didn't seem to be any)? Anyone have a torque number for those 2 bolts?
    Name:  P1020784 - Version 2.jpg
    Twinz - John
    Montpelier, VT
    '04 Fut Ash Black...de-restricted, Evo air filter, Bikpaintr re-rectified, Dingledork bungeed, QDs, RKA tankbag, Powerlet, Heattroller, waterproofed coils w/Stu_O HT wires, R&G sliders, Skidmarx hugger, Fenda-extenda, Bungee Buddies, Scottoiler (removed), Heli-Bars, Heaterz grips, Staintunes, Stebel Nautilus, Fuzeblock, Zumo 660, Acumen DGV, rebuilt forks w/Ohlins valves & RaceTech springs, Bef's R&G bar ends.
    '94 BMW R1100RS...sadly sold.
    '73 Guzzi V7 Sport...sold - that was dumb!
    '80 Guzzi V50II...gone but not forgotten
  2. #32
    PA USA
    Should think that the O-ring by itself should be sufficient. It seals onto the metal pump plate, correct? It's not like there's much pressure there.
    If the bottom of the tank stayed flat, that big o-ring on the pump plate (w/o red goo) would have been good enough. The service manual calls for that anaerobic stuff on the big o-ring, but I doubt any of the bikes were built with it from the factory. Mine sure was not.
  3. #33
    apriliaforum Member maro6613's Avatar
    May 2010
    East Lansing, MI
    That's sure good to hear. Did you use the stuff that takes 24 hours to cure or the 5 minute version?
    I used the 24 hour version. Figured I might as well do it right, didn't want to have to tear the tank back down in a few days (or ever again, hopefully).
    2003 Aprilia RST1000 Futura - 26k my miles
    Past Bikes:
    2004 Yamaha YZF-R1 (Sold!) - 13k my miles
    1995 Triumph Sprint (Sold!) - 15k my miles
    1990 Suzuki VX800 (Sold!) - 12k my miles
  4. #34
    PA USA
    Strength-wise, I've always had better success with the slower set stuff. Hopefully it'll also be more resistant to the EtOH as well.
  5. #35
    Aug 2008
    Montpelier, VT
    Hey, EVSY, how's your sensor repair coming?
    The Caswell epoxy has set up nicely and is quite hard and transparent. I'll give it another day to cure before reinstalling the tank. I did change the filter while in there, and the tank flange seems quite true so hopefully I'll have no leaks!
    Twinz - John
    Montpelier, VT
  6. #36
    Aug 2008
    Montpelier, VT
    My Fut's reassembled, doesn't leak (so far) and starts...yippee! Now EVSY, how are you coming with your repair?
    Twinz - John
    Montpelier, VT
  7. #37
    apriliaforum Junkie EVSY's Avatar
    Jan 2004
    NORTH WALES
    Quote Originally Posted by Twinz View Post
    I must admit to buying a new harness as there was one on the shelf for about £60 and have got some Loctite for repair of the old one to have as a spare,I could,t chance it for my big Euro holiday!
    "GUINNESS IS GOOD FOR YOU"
  8. #38
    Aug 2008
    Montpelier, VT
    Glad to hear you're back on the road!
    Twinz - John
    Montpelier, VT
  1. Fuel Sensor in case you were interested
    By bmwbob51 in forum RST1000 Futura (all years)
    Last Post: 04-07-2012, 12:34 PM
  2. Fuel sensor and gauge
    By bikeral64 in forum ETV1000 CapoNord (2001-2007)
    Last Post: 02-26-2011, 06:11 AM
  3. 2007 SportCity fuel sensor
    By bruiteur@yahoo. in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 08-24-2007, 06:08 PM
  4. WANTED: Fuel Sensor (pre1998 part)
    By dmunga in forum RS125 Euro-archive
    Last Post: 08-01-2005, 04:02 PM
  5. Fuel sensor
    By martin in forum Pegaso 650 Cube and IE
    Last Post: 07-25-2003, 02:48 PM
