Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Thread: my clutch wont work
  1. #31
    apriliaforum expert Glen1990's Avatar
    Nov 2011
    Barrow in furness
    ill also check the rod behind the little ball check thats ok should be a long rod then the little ball then the pin(nail looking thing?lol)
    Aprilia rs 50 2000
    Top performance Pink 75cc
    Doppler Endurance crankshaft
    Arrow racing exhaust with carbon endcan
    Dellorto 21mm carb(92 main jet)
    Stock air box modded
    Top performance Cdi
    Malossi reed block 0.30mm
    Conti race clutch kit
    14/47 Gearing
    Mono rear
    Michelin pilot sport tyres
    Rs 125 front master cyilinder
    Malossi upgraded clutch springs
    Rs 125 Headlight
    UPGRADES to come
    24mm mikuni flatside carb
    Double bubble screen
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    Full respray and frame polish
    Doppler air rear shock
  2. #32
    Jan 2012
    Bromsgrove, Worcestershire, United Kingdom
    i'll try that tomorrow yeah the basket has been off completely, i tried the other basket off my old engine which worked fine, how have you got your cable routed nicketynoo?
  3. #33
    Jan 2012
    okay so today i had all the clutch plates back out, took out the 2 pushrods, the ball bearing and the clutch arm, put everything back in as it should be and it still doesnt fucking work, i had the back wheel off the ground and operated the clutch at the actuating arm and it was still the same, still wont disengage
  4. #34
    Nov 2005
    Netherlands
    Did you adjust the Central Adjuster on the presure groop of the clutch? and did you try to adjust the cable tighter?
    Otherwise you must be doing something wrong mate, i am to tired to look up the whole set of instruction to asemble the clutch, but you must be doing something wrong somewhere.
  5. #35
    Jan 2012
    yeah the central adjuster is adjusted so when i felt resistance i came back 1/2 a turn, i tried other adjustments but no difference whatsoever. i tried adjusting the cable tighter too but the cable is pulling the arm as far as it will go
  6. #36
    apriliaforum Junkie nicketynoo's Avatar
    Oct 2011
    scunthorpe
    Sorry Josh not been looking on here for a couple of days. You've ruled out your cable by doing this test. What spares have you got? I have a few spare clutch parts that I could send you to try and find the problem if you like. think I've got a basket,plates ,pressure plate and original springs etc.
    If you want I'll send them you pay postage later and try the bits when you find whats wrong decide what you want to do. Make me an offer for the bit you need or send me them back and buy new.
    I'm not after making money just helping out!
    1999 rs50
    standard 50cc barrel+piston
    12mm phbn carb 86 main jet
    standard airbox
    conti racing clutch+uprated springs
    exhaust- Gianelli-carbon end can
    reeds- not sure
    bank account-empty
  7. #37
    Nov 2005
    Netherlands
    Think someone needs to send him some pics of how it all goes together, i really think somewhere something has been fitted wrong or something is missing.
    Im just to bussy at the momend to go alnd look stuff up.
  8. #38
    apriliaforum Junkie Michelet's Avatar
    Dec 2011
    Norway
    http://www.youtube.com/watch?v=xqxfoLDuw-8&feature=plcp
    Take a look at this video mate, it might help you sort out the clutch problems
  9. #39
    Sep 2011
    warrington uk
    Engine Always Screaming!
  1. An Aprilia dealer wont work on my APRILIA!
    By jandrade in forum General Motorcycle Talk
    Last Post: 07-19-2008, 05:59 PM
  2. My aprilia sr50 ditech 2004 electrics wont work
    By MattMan2727 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 07-14-2008, 12:16 PM
  3. My lights wont work!
    By unikarl in forum RS50 Technical
    Last Post: 08-18-2006, 05:56 AM
  4. OMG my clutch works
    By ckruzel in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 07-07-2005, 12:18 AM
  5. Is my clutch about to fail???
    By highside1000 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-07-2003, 09:13 AM
