Results 31 to 45 of 68
Thread: Take-off problem
  1. #31
    apriliaforum expert toddlamp's Avatar
    Nov 2007
    Laurel, MD
    The first swap is likely so soon in order to remove any metallic debris while the new gears break in.
    2010 SR 50 R Factory (max speed so far downhill/tucked: 70mph indicated)
    1. De-restricted (2.8.0)
    2. Leo Vince ZXR pipe
    3. NGK ZMR7AP (gap: 0.035")
    4. Malossi Multivar 2000 w/7.2g Rollers
    5. White contrast spring
    6. Red clutch springs
    7. Malossi TC
    8. Malossi VL13
    9. Harbor Freight Water Trap
    10. Stage 6 gear kit 13/39
    11. HGT Fuel Regulator @ ~118psi
  2. #32
    Vancouver BC
    That makes sense. haha I forgot to do mine 1500k over.. haha
  3. #33
    Nov 2007
    Laurel, MD
    Ha, might want to look into that. Any sentiments probably just fell to the bottom anyway.
    Once you get your 70cc setup back are you going to do a gear up kit?
    7. Malossi TC
    8. Malossi VL13
  4. #34
    apriliaforum Member Draftpunk's Avatar
    Jul 2011
    Sunshine Coast, Australia
    IMO. If your old rollers didn't have flat spots or you haven't put the sliders in the wrong way, your weights were and are again too heavy for you contrast spring.
    Good luck.
    mate
    2010 RS125 Gloss Black
    Arrow Exhaust (E Marked) | Moto Tassinari vForce3 Reed Block
    2002 SR50 Morini Ditech Matte Black SBK Replica 50cc
    Leo Vince GP can | 68cc Kit (Malossi) | Full Circle Crank (Malossi MHR HPC) | Primary gear kit (Malossi) | vForce2 reed block (Top Performances\Moto Tassinari) | 19mm bored throttle body
    2002 SR50 Morini Ditech blue 50cc FOR SALE (daily rider) 100aprilias/hr (80km/h)
    ECU "development mode" (apparently) | 19mm bored TB | Carbon reeds | Std. Variator | 6.0g Rollers [slightly heavy but good] (Malossi) | Std. Clutch | Red Contra Spring [Racing] (Malossi) | Blue Clutch Springs [Sport] (Malossi) | Custom Water Trap
  5. #35
    May 2011
    Finland
    Thanks everyone for answering. I'll check the gear oil today just to be sure. As for the rollers and contra: how can I make it work? When I tried a stiffer contra I needed very heavy rollers to compensate that (to bring RPMs back down). And when I added lighter rollers, RPMs were too high. I noticed my SR didn't accelerate well with lighter weights. Thanks still, could this just be solved with a new stock contra (or a white one) or a bit stiffer one?
    2010 SR50 R Factory - Piaggio Purejet
    ECU Derestricted (2.8.0) / LeoVince ZX-R / Water Trap / NGK ZMR7AP (.035") / +3° Woodruff Key
    Malossi Multivar 2000 / 7.5g Sliders / Malossi White Contra Spring / Polini Blue Clutch Springs
    Stage6 Wing Cooler Clutch Bell / Malossi Red Sponge Filter
    Michelin Pilot Sport SC 130/60-13 (front and rear) / Buzzetti Sidestand / Polished Variator Cover
    Lennes SR50 Aluminium Foot Plates & Radiator Grille / Kiesler Underseat / Stage6 Mirror
  6. #36
    Vancouver BC
    you aid you had problems before fix them before changing anything else
  7. #37
    Vancouver BC
    Quote Originally Posted by toddlamp View Post
    Yup, start with your gear set 13/39 and keep buying diff sets till I find the right one.
  8. #38
    Jul 2011
    Quote Originally Posted by Coore0 View Post
    Thanks everyone for answering. I'll check the gear oil today just to be sure. As for the rollers and contra: how can I make it work? When I tried a stiffer contra I needed very heavy rollers to compensate that (to bring RPMs back down)...
    There's nothing wrong with having heavy rollers if the setup works.
    ... And when I added lighter rollers, RPMs were too high. I noticed my SR didn't accelerate well with lighter weights...
    How much lighter are you talking? A few grams reduction overall will make a lot of difference.
    mate
  9. #39
    May 2011
    Finland
    Okay, good to hear that. I'll try a stiffer contra and match the rollers afterwards. And I tried 4.3g rollers with stock contra and stock variator and they were too light. RPM was like 9200 during WOT.
  10. #40
    Vancouver BC
    if you have multi var i would try and use the white contra spring. I tried the stock contra and just wacked out everything
  11. #41
    apriliaforum expert Alexandar's Avatar
    May 2011
    Skopje, Macedonia
    Personally I think that the Haynes manual is wrong. When I drained the oil the first time i drained it into a measuring cup and it was approx 100ccs. Seeing that people on the forum recommed 75ccs that is what i put in and that is roughly when the problem started (at the time I didn't realize it).
    As for seals i think there is only one or two and even if you filled it until fluid came out of the fill hole they should still be above the fluid level. I'm not promising there will be no damage but i see it as unlikely. If you are running on too low of oil you will likely damage the gears as i suspect the slow take off is caused by lack of lubrication and that is creating heat.
    I would check the level and if low add some more in 10-20cc increments and see what happens.
    For piaggio 110ml, minarelli and morini 75ml of gear oil also in the factory manual is stated that piaggio uses 110ml...
    And on the oil dip stick we are looking for the second line, not the first if we want the see the quantity of oil that we have in the gearbox
    SR DiTech Piaggio c361 2005
    Polini Kit 70cc
    Polini Bowl
    Original Piaggio Contra Spring
    Rollers Malossi HT 7.5 grams
    Malossi Special Belt
    Malossi Oil 7.3 & Agip City 2T
    Malossi Gears HTQ 14/39
    Gianelli Reverse
    Air Diffuser 20mm
    Clutch Stage6 Torque Control MKII
    RMS Crank
    Woodruff Key 3degrees
    Malossi Air Filter
    Polini Carbon Reeds 0.35
    Water Trap
    Fuel Pump Mod
    Ecu Derestricted version 2.8.0
    Spark Plug NGK ZMR7AP
    Sava MC 29 Sporty 3+
    Lights Philips Master LED spot LV 10wx2
    Brembo brake pads
  12. #42
    Vancouver BC
    I better mark that in the haynes manual
  13. #43
    May 2011
    Finland
    Thanks for answers! I appreciate that.
    Today it has been raining so I haven't touched my scoot. Will check things tomorrow... But my white contra is definitely faulty, since it didn't even fit properly to the pulley.
  14. #44
    apriliaforum expert Mr. Scootswell's Avatar
    Jun 2006
    Ski-Town, MI
    I'm having similar probs after upgear install. Makes me sick how many times ive tuned my carb and tranny. I'm subscribed to this thread, and will be watching it. I'm gonna check my oil when I get home too...
    2009 SR70(R)
    UNDER CONSTRUCTION
  15. #45
    Nov 2007
    Laurel, MD
    Adding a gear-up kit without increasing horsepower will cause a slower take-off. My issue was that the scooter would absolutely crawl ("By crawling I mean it just goes slower than walking") until a speed of approx 15mph before accelerating. For me, I even swapped the stock gears back in and the take-off was exactly the same and just as bad. That is how I ruled those out of the equation.
    7. Malossi TC
    8. Malossi VL13
  1. if you take off the front signals, does it mess something up?
    By deputydog95 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 01-26-2004, 08:58 PM
  2. Anybody (U.S.) have these take-offs 4sale
    By suzuki1 in forum RS50 Technical
    Last Post: 12-05-2003, 07:29 PM
  3. How do I take off the triple clamp?
    By JJ_008 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-06-2003, 02:22 PM
  4. How to take off the variator
    By texture in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-01-2003, 03:29 PM
  5. Race Take-Offs?
    By gtoddh in forum SL1000 Falco Forum (all years)
    Last Post: 04-23-2003, 02:05 PM
