Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Thread: Cam chain rattle, 3500rpm.
    Dec 2011
    Earth
    My falco has developed a cam chain rattle when accelerating through roughly 3500rpm. It's pretty noisy and i can hear it over the aftermarket cams. Sounds like the cam chain wants to escape!
    Im presuming this is not a normal noise (i know these engines are very noisy) and i need to know what i should do about it. How hard is it to change the tensioner?
    any guidance is appreciated.
    Dale
    apriliaforum Member lebrisw's Avatar
    Dec 2009
    FRANCE -RENNES
    which year is your falco ? if 1999 or 2000, changes the chain tensioner.
    the part that give pressure to the chain. # 9
    http://www.af1racing.com/store/Scrip...dCategory=1097
    those parts were not strong enought on first models.
    it works with the oil presssure and the old oil stay into it, and make them stop working...
    I hope you understand me.... changes those 2 parts, done on mine 2 years ago.
    Dec 2011
    Earth
    Quote Originally Posted by lebrisw View Post
    Yeah it is an early one. 2000 or 2001 I believe.
    Is it just part number 9 i need or do i need parts 10 and 11 as well?
    looking at its position on the engine it doesn't seem like such a hard job. Am I being nieve?
    Thanks,
    Dale
    Dec 2011
    Earth
    Really weird, the site didnt post my reply.
    Its either a 2000 or 2001 model. It's red, anyway.
    Is it just part 9 i need, or will i need 10 and 11 as well?
    Doesn't look like a hard job. is that correct? Anything i need to remember like crank position or anything?
    Dale
    apriliaforum expert Aladinsaneuk's Avatar
    Nov 2006
    Blighty
    red models were made early - they were the faster ones along with the black ones
    so its 1999 or 2000 - may have been registered later
    www.ridersite.com - UK home of the Falco Community
    witty banter and sarcasm available for all....
    Dec 2011
    Earth
    Thanks Alad.
    Cam chain is ordered. didnt bother with the plug, just got a new gasket.
    price was £92
    apriliaforum expert D-Rider's Avatar
    Jul 2005
    Coventry, England
    Quote Originally Posted by dalemac View Post
    Pete's right about the year. Lift the saddle and look for the sticker on the subframe rail - that will tell you when it was manufactured and the market it was built for.
    sydney australia
    Thanks Alad.
    price was £92
    It will be the tensioner, not the chain.
    I have seen many of these bikes with big miles on them & not changed a chain yet.
    Plenty of tensioners have been changed though.
    Dave Ward
    Moto Italia
    Aprilia-Ducati-Moto Guzzi
    www.motoitalia.com.au
    0432 441 985
    Dec 2011
    Earth
    Quote Originally Posted by FORZA View Post
    Dave Ward
    Moto Italia
    0432 441 985
    Apologies, i meant te cam chain tensioner has been ordered.
    Am i right in thinking that there is a tensioner on each cylinder? If so - how do i know which one to replace?
    Dale
    apriliaforum expert anzacinexile's Avatar
    Jan 2005
    UK South Coast
    False economy to do one. If one is knackered, the other wont be far behind
    Chris
    Probability factor now 1:1, normality has been returned. Anything you can’t deal with now is your own problem
    Aug 2007
    Incontinental Europe
    But rear one is so much easier to replace than the other ......... If that is the only one worn out, then I would only replace that one!
    Another thing to note is lateral play in the secondary balance shaft between the rear head camshafts can also cause noise. This kind of sounds like a train moving. You know, the sound the train wheels make transferring between consecutive rails. ch .. ch .. ch .......... ch .. ch............... ch .. ch .. ch .......... ch .. ch............... ch .. ch .. ch .......... ch .. ch............... ch .. ch .. ch .......... ch .. ch............... ch .. ch .. ch .......... ch .. ch...............
    Nov 2006
    Blighty
    Dec 2011
    Earth
    The rattle is definitely more of a cam chain rattle. Anyhow, how would i check the balance shaft for lateral play? is it something i can do while I am in there checking the valves?
    Jan 2005
    UK South Coast
    You'll need a DTI (Dial Test Indicator)
    http://www.diseno-art.com/products/t...indicator.html
    Chris
    Dec 2011
    Earth
    Quote Originally Posted by anzacinexile View Post
    DTI Purchased.
    So how do i check the free play and what would be considered as too much play?
    Thanks,
    Dale
  1. Couple questions - Sidestand sticking? Cam chain rattle?
    By mysubaruimp in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-22-2005, 01:19 PM
  2. Broken Cam Chain (Interesting)
    By Micah / AF1 Racing in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-21-2004, 10:34 AM
  3. Cam Chain Failures (V990) READ This
    By Micah / AF1 Racing in forum General Motorcycle Talk
    Last Post: 06-12-2004, 05:00 PM
  4. Cam Chain Tension
    By MaxFromUK in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 02-11-2004, 11:33 AM
  5. help with cam chain tensioner
    By rimjob in forum Pegaso 650 Cube and IE
    Last Post: 11-29-2002, 08:50 AM
