Results 1 to 6 of 6
Thread: Mirror removal problem AA500 - normal RH thread??
    apriliaforum newb Misterguru's Avatar
    Aug 2011
    Evansville, IN
    Question Mirror removal problem AA500 - normal RH thread??
    Hi, I just bought a 2004 AA500 with only 972 miles. It was one of those sweetheart deals you hear people talk about where it was owned by an old man who never drove it. But the problem is the widow of this man let the bike set outside for over a year.
    The mirror posts are pitted with rust and some of the weather gaskets (around the intercom - I guess that's what they are) are dry rotted.
    The left mirror came right off, but I am seriously afraid that I am going to break the right one if I try any harder to remove it.
    I have soaked it with PB Blaster... it is a normal RH thread, right?
    They need to be replaced or removed, sanded and painted.
    The only other problem is the failed Regulator/Rectifier, but a new CBR600RR fixed that tonight (thanks for the writeups!).
    Thanks in advance!
    Tim
    PS, I suppose I can dremel-brush, mask off and paint it in-place, but would rather extract it!
    Apr 2012
    Cottage Grove, Oregon
    Sharp-looking scoot! Someone should be along shortly to help you out (I have to plead ignorance with respect to the threading of the mirror). If you should happen to break it off (heaven forbid!), there's always the option of drilling the stub and using an E-Z Out tap to remove it, the replacing the mirror with an after-market version. Emglo makes a few that would work (I have 2 pairs on stand-by, from my motorcycling days).
    I can tell you that my 2004 Scarabeo GT had a right hand thread on the left and a left hand thread on the right. Just like Yamaha motorcycles. I would not be surprised if your Atlantic was the same.
    _________________________
    Regards,
    MillCreek
    Snohomish County, Washington USA
    2004 Scarabeo 500: serial number 004 and built in July 2003 (Sold 5/2012)
    2008 Suzuki DR650 (Sold 5/2012)
    2012 Suzuki DL650A
    Two road, three mountain and one folding bicycle
    RDU/ North Carolina
    Thats Std European mirror mounting 8-10 mm My beo mirrors I think are not threaded where the Bar /rod goes into Nut fitting and get squeezed by tightening use KROIL you crack the Nut and rotate slowly the mirror rod in fitting lil mo kroil rotate bck n forth no need to break anything
    Aug 2011
    Evansville, IN
    OK, the right mirror post was LH thread! Now, to order some pretty mirrors!
    Also the throttle moves easily but is not returning to zero when I remove my hand. I cleaned inside the plastic housing.
    I am guessing the cables need lube or the return spring is rusty.
    Jun 2012
    S.FL
    Yeah, I had the same problem..Figured it out finally after almost breaking my knuckles.. :-)
    My Regulator seems to be going bad too... WIll post in proper thread to get info. (votage reads below 12v while running)
  1. LH/RH Thread?
    By duncandisorderl in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 11-06-2007, 08:50 AM
  2. Problem AA500 max 6500 tr/min
    By mizzio in forum Aprilia and Piaggio 500cc
    Last Post: 08-11-2006, 04:50 PM
  3. Coolant Pump Impellar RH thread?
    By Jerry in forum RST1000 Futura (all years)
    Last Post: 07-14-2005, 06:56 AM
  4. Oil Filter Removal Problem
    By Manfetti in forum Aprilia and Piaggio 500cc
    Last Post: 06-07-2005, 06:23 PM
  5. mirror removal
    By SiR50 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 05-19-2004, 03:04 PM
