mines ok with the 14/47 still lifts the front end if your not too careful
Aprilia rs 50 2000
Top performance Pink 75cc
Doppler Endurance crankshaft
Arrow racing exhaust with carbon endcan
Dellorto 21mm carb(92 main jet)
Stock air box modded
Top performance Cdi
Malossi reed block 0.30mm
Conti race clutch kit
14/47 Gearing
Mono rear
Michelin pilot sport tyres
Rs 125 front master cyilinder
Malossi upgraded clutch springs
Rs 125 Headlight
UPGRADES to come
24mm mikuni flatside carb
Double bubble screen
Yasuni R3 exhaust
Gear indicator
Custom rearsets
Full respray and frame polish
Doppler air rear shock
I dont understand how you can lift the frontend without being careful..
I have to push the forks down to make a wheelie, unless i pull out 1 gear completely and hit right at the 2. gear power band![]()
Push the forks down? you mean give a tug on the handlebars to lift the front wheel...
Mine lifted the front wheel of the ground really easy if i just accelerated reallly hard in the first 3 gears sitting upright, even leaning forward you could feel the front end wanting to lift even up into 4th gear.
To wheely a bike like a RS50 is a bit harder, and you would need to lean back and maybe even give a little tug on the handlebars to get it to go, but its not something you should try as its not to good for the bike if it comes back down hard on the frontwheel.
yeah pretty much what i meant is mine still has a alot of take off power will lift the front wheel i think patrick put it a better way lol :P
Aprilia rs 50 2000
Top performance Cdi
14/47 Gearing
Mono rear
Rs 125 Headlight
UPGRADES to come
Yasuni R3 exhaust
Gear indicator
Custom rearsets
Ah, now I understand what you guys mean!
Like a few cm off the ground?
Had the front wheel nearly 20cm off the ground 10mins ago, was out driving and figured out I had to try it.
Managed to do it quite easily in 1,2 and 3 gear. Just pulled the gears out completely!
ahh well just received a email from ezparts they do not ship to the USA anymore..
and the search continues.......
EXCREW RIP 1/08/06
01 RS50/72cc MetraKit HM, MK cdi, Arrow CF, 21mm del phbg, uprated Clutches, Cf reeds, DiD chain, Galfer front and rear ss brake lines, Tinted Screen...
01 Rieju rs1-50 stock stock stock :thumbdown
Backup motor 04 AM6 motor, athens74, 24mm del, Doppler ER1 crank, Barnett Clutch, stock pipe
im sure theres a ladd on here who is in the usa and ordered from adrenalin pedstop over here in the uk.....
send them a email but remember it may take a lil longer than normal to recieve ur parts
Engine Always Screaming!
There are european shops that ship to the USA, wen i wanted to order and ship some parts a few weeks back i got a pretty nice shock on the shipping cost, parts where like 20 euro's, and shipping cost for a packadge bellow 2 Kilograms was 40 Euro's... WTF? i send something like 2 years ago to the USA wich was almost 2 Kilograms and it was something like 22,50 euro's, atleast less than 25 euro's for shipping.
I have had good luck with orders from UK there shipping is usually reasonable between 10-15 for light items that are not real big. fairings and things will be more because of size I assume and every where else the shipping just sky rockets. also ebay they ship as a gift and no taxes
Hey Speed,
Check out Treats--they are doing a lot to support our bikes. They are in the States and they import lots of goodies. They are in SF and I regularly visit them and chat about potential products to stock. Top Performances is one of venders they support--the trick is getting the part number. If you can scrounge that up then Treats can probably get it for you.
Also since you are in the States you might want to check out Bats (Bay Area Two Stroke) --a local forum for two stroke bikes. There's a couple of cats on there that have serious Aprilia knowledge.
TopPerformances 6th gear original part number: 9919080
Sweet thanks Patrick. I'll get that number over to Benji. Did they every make this part (or something like it) for the Derbi engines? Also, do you have a Top parts number list or a place online that lists them?
mine when it was fine wanted to wheelie when ever i hit powerband through 1st & 2ndor dropped/slipped the clutch in 1st ;P
had her tuned perfectly, done just over 70mph on clock easy!!! even got her off the clock occasionly (but with 14/47 gearing) haha
oo im gunna miss her :'( o well bring on the next project![]()
what do you think off mine?comments please!!
i think you will do better with this next bike ryan, it looks pretty clean and less miles on the bottom end than your old one and will have a pretty new top end on it soon so will be a good runner
you putting the polini flatside carb on aswel?
and are you getting the turbo kit exhaust or changed your mind?
maybe a top performance 6th would be a nice touch for the new one aswel as you will still have good acceleration but when you want to sit at top speed it will be faster
im really looking forward to getting my set up done gonna get alot of saving i will do the gear box 6th gear when i rebuild my engine again but really you got 70mph on the flat with that 50cc polini kit? what esle did you have full set? i was looking at the alloy polini 50mm kit its cheaper that the tp pink
Aprilia rs 50 2000
Top performance Cdi
14/47 Gearing
Mono rear
Rs 125 Headlight
UPGRADES to come
Yasuni R3 exhaust
Gear indicator
Custom rearsets
