Results 1 to 7 of 7
Thread: I want to change tires
    Apr 2012
    Culver city
    I ordered a new set of Michelin pilots and I was wondering if any one has ever changed there tires them selfs. How did you brake the bead? Is there a tube? I have tire irons but I have never changed a tire on a motorcycle or a scooter and I want to do it right.
    2009 SR 50
    2.8 map
    Malossi 70cc big bore kit
    Malossi delta clutch
    Malossi Primary gear set 14/39
    Malossi blue contra spring
    Malossi Torsion control
    Malossi Multivator kit 8.4 gram rollers
    Malossi special belt
    Malossi Torque drive pulley half
    Malossi roller crankcase
    Malossi rear shock RS24/10
    Malossi Pinwheel shaft
    Malossi filter in modified air box
    HGT fuel pressure regulator 125 psi
    leo Vince ZX-R
    HGT 20mm bore throtle body modifacton
    64mph on the flat 72mph on hill both tucked
    apriliaforum Junkie oluckymana's Avatar
    sydney australia
    ....some places do free fitting if you buy the tires from them....by hand is a real bitch... if you really want to do it yourself you may be able to break the bead using your boot heels by standing on the tire after it is deflated...and be careful of damaging your rims with tire irons....good luck...
    ....let's have another drink....
    2011 Black Mana GT ABS
    2006 SR70
    Morini
    Polini BBK
    Chrome Leo Vince ZX pipe
    Motoforce R6 shock
    ECU in development mode
    (more when I find out what)
    Apr 2012
    Culver city
    I got the tires on the Internet for cheep I guess If I can't get the back one off by hand I will pay to have them done. Are there tubes?
    2009 SR 50
    2.8 map
    leo Vince ZX-R
    Sep 2008
    Nice weather AT LAST! Winnipeg, MB
    I've done both of my tires and it was no problem breaking the bead... After removing the Valve Stem, I used the Tire Iron and pressed down on one location till it "broke"...
    I was fairly surprised at just how easy it was...
    Anger is an ugly Mistress…
    Apr 2012
    Culver city
    So no tube I take it.
    2009 SR 50
    2.8 map
    leo Vince ZX-R
    sydney australia
    ...these days most tires are tubeless...unless with spoked wheels...
    2006 SR70
    Morini
    Polini BBK
    Motoforce R6 shock
    apriliaforum prov-nov Senned's Avatar
    Jul 2011
    Denmark
    If You do it yourself and dont want to damage the rim, then use this guide:
    http://www.youtube.com/watch?v=0Pfp2Z9k0n0&feature=youtube_gdata_player
    Aprilia Mille RSV . Year 2000 . Powercommander III . Akrapovic slipon . Derestricted . Map2 . Garbro chip . Renegade airbox (not installed) . Collector mod (not installed) . Pirelli Angels . Brown connector mod . MRA Double Bubble Screen . English racing green like my B.S.A. B31 .
  1. Not Wanting To Change Gear Sometimes....HELP!
    By h2ku in forum RS50 Technical
    Last Post: 12-02-2008, 03:18 PM
  2. Want to change roller weights, no impact wrench
    By scootn-N-thelou in forum Non-USA model Aprilia Scooters
    Last Post: 06-01-2008, 08:33 PM
  3. Cost to change tires
    By fire1427 in forum Aprilia and Piaggio 500cc
    Last Post: 10-11-2007, 01:22 PM
  4. Replies: 13
    Last Post: 11-16-2004, 04:50 PM
  5. It was nice to ride, but I wouldn't want to change it for my Falco.....
    By Exdukenut in forum SL1000 Falco Forum (all years)
    Last Post: 02-29-2004, 07:33 PM
