Results 1 to 4 of 4
Thread: Where to get coolant lines
    apriliaforum prov-nov SteveTR6guy's Avatar
    West Chicago, IL
    Question Where to get coolant lines
    Related to my "Blew it up" thread, I need to replace all the coolant lines on my Beo 150. Some are readily-available straight hoses that the FLAPS would have cheap, but 2 in particular (5 and 7 on the diagram on AF1's site) are special (molded T-fittings with one side bigger than the rest) and I was thinking I'd need to get OEM parts. Until I found that one is $68 and the other is $58. $126 for 2 coolant lines seems a little steep. Has anyone else faced this harsh reality? What did you do? Can copper plumbing fittings be made to work? I know they could handle the pressure, but the heat may be an issue.
    Anything to avoid paying 125 bucks for 3 feet of rubber hose.....
    Steve
    Steve
    2001 Scarabeo 150, Malossi 177 cylinder kit/cam/hi-speed variators/secondary gearset, Gianelli exhaust
    1980 Vespa P200e, ground-up resto to original Italian spec, Porsche Orient red (the wife's scooter)
    1969 Triumph TR6 (car) in a thousand pieces, undergoing ground-up resto/mod
    1981 Honda GL 1100 Goldwing "naked"
    Jun 2008
    RDU/ North Carolina
    Those Yer Stat hoses You/Id Make them up For Id pay that Are you saying that your hoses Blew out ? I would Use metal Connectors From the likes of Hayden they make good cooling systems upfit stuff For that Long hose you could even make that whole run copper Sweat A T at stat connection You can look on Wall in bck Auto parts store at Pre made Heat hoses Youd be shocked You migh find a Hose so similar Twill work I did that With Valve cover Breather hose Find pre made Heater hoses rom Auto almost right Cut n make it work pretty easy. Could wind up stronger N cooler than Factory any copper will cool quicker and wick heat away Strap copper run to Frame With clamp/s Usae bendable copper like lquid line use in Ac work (home depot)
    Clearwater, Fl
    Just remember if you start adding copper tubing to make sure you are using a mixed metal coolant afterwards so the soft copper tubing and the aluminum engine block don't start an electrolytic reaction against each other.
    Jun 2008
    RDU/ North Carolina
    the Orange Dex cool or Eq Shld Do it ..
  1. Tools --- Where To Get Them ????
    By themadatter in forum RS125 Euro-archive
    Last Post: 09-14-2003, 12:35 PM
  2. Chain Splt/rivet tool,,any2 selling cheap, know where to get CHEAP
    Last Post: 08-24-2003, 05:36 AM
  3. Where to get repacking stuff?
    By amaner in forum SL1000 Falco Forum (all years)
    Last Post: 08-06-2003, 03:37 PM
  4. any one knows where to get a back wavey disk ?
    By spanairRS250 in forum RS250
    Last Post: 07-25-2003, 11:59 AM
  5. where to get aprilia paint from?
    By brucey12 in forum RS125 Euro-archive
    Last Post: 05-26-2003, 04:32 PM
