Results 1 to 5 of 5
Thread: Will a 2007 Tuono Rear Sprocket Fit a Tuoldo?
    apriliaforum Member KIRK!'s Avatar
    May 2011
    Concord, CA
    I found a 43T from a 2007 and am wondering if it's the same bolt pattern and chain size (525) as my '05.
    Thanks!
    A casual stroll through the lunatic asylum shows that faith does not prove anything.
    -Friedrich Nietzsche
    Stroudsburg, PA
    If it is reversible like the one on this link then yes it will work. The bolt pattern and 525 size is the same (unless the bike was converted to the smaller lighter 520 size) but the offset is slightly different depending on which side is facing out. http://www.af1racing.com/store/Scrip...idproduct=2046
    May 2011
    Concord, CA
    I don't see any offset.
    Stroudsburg, PA
    It will bolt up but you may have a slight chain alignment issue. A number of people are running second gen rear wheels which have more offset on their first gen bikes without issue so you may not have any issue with that sprocket. Unless it is insanely cheap and you're willing to eat the cost of it if it does not work out in my opinion you'd be better off buying a new sprocket.
    May 2011
    Concord, CA
    Good advice. Thanks!
