Results 1 to 15 of 23
Thread: radiator water
    apriliaforum Member Thepoolman's Avatar
    May 2010
    Cornwall
    radiator water
    hi
    i have just been on a trip covering 1000 miles and about halfway i noticed my radiator overflow level was low
    so i topped up that plus checked water level in radiator which was looking low also. then had to do again once i got home. is this normal or am i missing something? like pipe leaking or vapour escaping from something that uses the water up.
    2000 Yamaha Virago 535cc
    2001 Suzuki Burgman 400cc
    2005 Honda XR 125cc
    May 2010
    Surrey
    Doesnt sound normal, what colours your oil? as Id be worried about head gasket if it was a car.
    Jan 2011
    Manchester, UK.
    Hi Poolman
    My Strada's done 48,000 miles and I've only had to top up the coolant a couple of times.
    If you're topping up more frequently than normal, then the coolant's leaking out somewhere. Check all the hoses and radiator cap for leaks with the engine running (don't burn yourself!).
    If the coolant's leaking into the engine, then you'd probably get a white goo inside the oil cap.
    May 2010
    Cornwall
    hi thanks for help. hi joesopp no goo in oil cap and i think it could be just the cap to the radiator, as it all started when i opened it first time to be nosey and check water level,
    bike is due service in 2 weeks so i will ask them to check all hoses. as i have just remembered that it once steamed from radiator cap so could be old rubber seal.
    thanks for both for help i'll keep you updated
    2005 Honda XR 125cc
    apriliaforum expert Frodo's Avatar
    Jul 2007
    Paekakariki New Zealand
    My bike's done 86,000km and doesn't lose any water between changes (every two years). Shouldn't be difficult finding the leak given the colour of the antifreeze in the coolant. Most likely through a crack in the radiator or a hose.
    Frodo
    2006 Pegaso Trail
    New Zealand
    May 2010
    Surrey
    Glad it doesnt sound too serious
    apriliaforum Junkie ytc1's Avatar
    May 2010
    St Helens, UK
    Quote Originally Posted by Thepoolman View Post
    hi
    Check around the pipe that goes to the pump, you may feel a slight dampness there (except when it is hot it will have evaporated). If it is damp, then there may be a slight seepage. Just get a tie clip and pull it as tight as possible between the "proper" clip and the base.
    It works a treat.
    I'll dig out a picture for you.
    Dec 2005
    Kuala Lumpur, Malaysia
    Hi everyone
    Coolent is leaking from the radiator cap. Made a new rubber seal from old motorcycle tube. The leak stopped.
    Is this Ok? Will this affect the efficiency of the cooling system?
    Your views highly appreciated.
    KlPegaso
    Kuala Lumpur
    Malaysia
    Jan 2011
    Manchester, UK.
    Quote Originally Posted by klpegaso View Post
    Yes, this is Ok! Without a leak, the cooling system will work much more efficiently
    Dec 2005
    Thanks Joe.....
    May 2010
    Cornwall
    Quote Originally Posted by ytc1 View Post
    It works a treat.
    thanks i look forward to seeing a pic.
    2005 Honda XR 125cc
    May 2010
    Cornwall
    hi guys just had bike pass MOT last weekend had its 12500 mile service this weekend and i may need a Radiator i found a company called Aprilia Parts has anyone used this company before? if so what was there service like. Plus could i as a novice replace this myself. though i am happy let the pros fit it
    2005 Honda XR 125cc
    Jul 2007
    Its possible that the radiator is leaking where the fan is fitted. I would try to repair it, rather than buy new.
    I don't think it would be difficult to remove but I haven't done it myself.
    Frodo
    2006 Pegaso Trail
    New Zealand
    May 2010
    St Helens, UK
    Do you mean :-
    Aprilia Geninue Parts - http://www.apriliagenuineparts.co.uk/
    Aprilia Part Online - http://www.apriliapartsonline.co.uk/
    or
    Aprilia Parts Buyer - http://www.apriliapartsbuyer.co.uk/
    As a google search for Aprilia Parts hits these 3 (and more)
    I use the Blackburn based Rocket Motors site - http://www.apriliapartsbuyer.co.uk/ Service is fine, you just have to wait the standard 10-14 days for anything Aprilia to appear.
    When the securing lug broke on mine, I asked a rad repair specialist to have a go, but they were unable to fix it due to the delicate nature of the fins. So I bought a new one.
    Fitting is easy, there are a couple of pictures of access to the rad on my blog http://blog.maui.co.uk/index.php/ytc...-while-waiting , I had to drop it while doing the valve clearances.
    May 2010
    St Helens, UK
    Are you suggesting a rad seal fluid addition repair ? Or a slap some sticky gunky stuff on the outside type repair ?
