Page 5 of 68 FirstFirst ... 345671555 ... LastLast
Results 61 to 75 of 1006
Thread: Rosscofats 70cc Build Thread.
  1. #61
    apriliaforum expert NoNameForEver's Avatar
    Sep 2008
    Northern Europe
    Well, since you are going to split the case and the pump is internal, I just thought it made sense..
    Glyptocephalus cynoglossus lover
    Quest for no 3D glasses
  2. #62
    apriliaforum expert toddlamp's Avatar
    Nov 2007
    Laurel, MD
    Where did you get the horn for $38?
    2010 SR 50 R Factory (max speed so far downhill/tucked: 70mph indicated)
    1. De-restricted (2.8.0)
    2. Leo Vince ZXR pipe
    3. NGK ZMR7AP (gap: 0.035")
    4. Malossi Multivar 2000 w/7.2g Rollers
    5. White contrast spring
    6. Red clutch springs
    7. Malossi TC
    8. Malossi VL13
    9. Harbor Freight Water Trap
    10. Stage 6 gear kit 13/39
    11. HGT Fuel Regulator @ ~118psi
  3. #63
    Vancouver BC
    Amazon I'll see if I can fins it again
  4. #64
    Nov 2007
    Laurel, MD
    Quote Originally Posted by Rosscofat View Post
    Ok thanks. I found it on Amazon but not for $38.
    7. Malossi TC
    8. Malossi VL13
  5. #65
    Vancouver BC
    there is lots for 50$ but there is a few that are 38 there was 4 left a week ago
  6. #66
    Nov 2007
    Laurel, MD
    Not doubting you just really looking for one for less $$$. Thanks! I'll keep looking.
    7. Malossi TC
    8. Malossi VL13
  7. #67
    Sep 2008
    Northern Europe
    How about this.. You can get it here..
  8. #68
    Nov 2007
    Laurel, MD
    Currently I get all of my horns from my local junkyard. I get them dirt cheap (if not free). Currently my BMW K75 has a pair of horns out of a Lincoln Towncar. They are super loud. I took one of those and installed it in the typical location (behind the leg shield near the ECU) but I find that location to be too low down and more importantly too isolated and secure. While better than the stock horn it is muffled by the enclosure it's in. The stock location has several openings for the sound to permeate from but there just wasn't enough space for the large horn. I'm hoping that the PIAA Slim horn is the best of both worlds.
    7. Malossi TC
    8. Malossi VL13
  9. #69
    Parker Colorado
    This is 2 threads now that have turned into Horn threads.... I keep looking here for updates to the build and keep seeing Horn stuff :-(
  10. #70
    Vancouver BC
    well a update is I have finished wiring my resistors to stop the hyper blinking and service light on the scoot.. I pmed u the list Rich, I guess my email is failing right now because I can not view it at all from home
  11. #71
    Vancouver BC
    Got the spare air injector in.. it does not look any diff then anyone elses that have posted pics.. same brown O rings that everyone else had. HUGE box about 10x10x10 for this thing.. haha
  12. #72
    apriliaforum expert captdan's Avatar
    Apr 2010
    Florida
    You probably already know this but be sure to keep the metal cap on the end of the injector in place until the injector is used. It keeps that Teflon o-ring compressed.
    2009 SR50 Factory
    20 mm Bing Throttle Body
    Water Trap (Kobalt tapped with 1/4" NPT brass drain)
    Castrol Power RS TTS
    Castrol Syntec Gear Oil- 75W-90
    Oil Pump Flow Increased
    NGK ZMR7AP-(.030-.032) (Indexed @ 12:00)-
    Leo Vince ZX-R
    Malossi RS24 Rear Shock
    5.0 and 5.5 DP Sliders- Red Springs
    8mm Mirror Risers/Extensions + 30mm Washer
    Aprilia Emulsion Bleed Valve
    LED Tail/Brake Light
    Black Tunnel Covers
    Rear Tire- Pirelli Diablo Performance 140/60P-13
    Front Tire- Pirelli SL 26 Performance 130/60LX-13
    Top Speed (Digidash)-50-51 MPH @ 9100 RPM (Flat Road/Tucked)
    Rider Weight- 215 lbs
    20,200 miles-02/2013
    Yeah, Coulda' Bought A Harley- But Chicks Dig Scooters!!!!!:
  13. #73
    apriliaforum expert TheChef's Avatar
    Aug 2010
    Surrey,B.C
    Any news on when your getting it shipped back?
    09 SR Factory
    "Boo"
    Malossi BBK
    2.8.0 ECU LEOVINCE ZX-R ZMR7AP .035
    MALOSSI Multivar 2000 Yellow BGM clutch springs Green contra spring Reeds VL13
    8gm Dr Pulleys Husky Watertrap
    Gen III Adjustable High Gain Tuning Regulator 118psi
    Woodruff key BGM pod filter
    Fuel pump fix 40mm riser Stretch kit
    110kph.
  14. #74
    Vancouver BC
    Before July. Is all I know. I am fine with that lots of time to ride it . Can't rush art.
  15. #75
    apriliaforum prov-nov polepeach's Avatar
    May 2012
    Birmingham, United Kingdom (GB)
    Brilliant,
    Aprilia SR 50
    My Aprilia SR 50 is 2010 White with the Red Grey and Black Decals,
    it has been De-restricted and the fastest done 65+ mph off the clock.
    My bike is my pride and joy and i keep it under high maintenance,
    Exhaust: Giannelli Chrome and Carbon fibre race can, Renthal Bars. alot more is to be done until further notice.
