Page 4 of 76 FirstFirst ... 234561454 ... LastLast
Results 46 to 60 of 1127
Thread: Rosscofats 70cc Build Thread.
  1. #46
    Vancouver BC
    I did not think you were bored.. if there is a tornado take pics!
  2. #47
    Sep 2008
    “I reject your reality, and substitute my own.”
    Your engine just arrived!!!!!
    17:50 local time.
    Anger is an ugly Mistress…
  3. #48
    Vancouver BC
    Sweeet I hope in 1 piece my dad spent a good amount of time on that box
  4. #49
    Vancouver BC
    Picked up a few extra fuses and my Dad and I re mounted the horn in a better spot that gave more room under the "hood" more then likely will paint the strip of metal black to blend in a bit more. Also fixed a broken part of the top cover Dad takes all the credit for this one.
  5. #50
    Sep 2008
    Rossco, if you want your engine black like mine, let Rich know asap.
  6. #51
    apriliaforum expert NoNameForEver's Avatar
    Sep 2008
    Northern Europe
    Pink...?
    Glyptocephalus cynoglossus lover
    Quest for no 3D glasses
  7. #52
    Vancouver BC
    Lets do it black then! ill Email him also
  8. #53
    Feb 2011
    Seattle, WA
    I replaced my horn with a Hella horn. It currently sits under the bike attached very near the ECU of the bike, within the body work. It points downward which is not ideal, but it much louder than stock. :-)
    2007 SR50 - Morini
    ECU de-restricted by HGT
    Leo Vince ZX pipe - Chrome
    Malossi sponge air filter
    3 degree woodruff key
    Malossi MultiVar 2000
    Malossi white contrast spring
    Malossi Torsion Control
    Dr Pulley 7gr sliders
    Malossi Special Belt
    YSS 300mm rear shock
    LED corner lights
    Hella horn - Beats the stock horn!
    *pending to be installed*
    Malossi 70cc BBK
    Malossi V12 reeds
    Dr Pulley 7.5gr sliders
    HGT Fuel Regulator
    Kobalt Water Trap
    **Needs repair**
    Battery dead from Winter storage
  9. #54
    Vancouver BC
    That is where most ppl put theirs.. but I wanted mine up at handle bar level.. most horns are high pitch which can be bounced very easy.. so higher and more direct it aims forward the better.
  10. #55
    Feb 2011
    Seattle, WA
    You using the factory horn or something else?
  11. #56
    Vancouver BC
    im using a PIAA slim hon
  12. #57
    Feb 2011
    Seattle, WA
    Wow, didn't know that existed. Looks good. I paid a bit less for the Hella, but it's physically larger so I had to get creative on the install.
    Now, I think we both paid too much and could have got this. It's small
    http://www.amazon.com/HELLA-00276838...im_sbs_auto_24
    Much cheaper, just as loud if not louder than both of our horns.. combined. It takes dual hella's to do 118db, I figure a single is about 112-115db.
    2007 SR50 - Morini
    LED corner lights
    Malossi 70cc BBK
    Malossi V12 reeds
    HGT Fuel Regulator
    Kobalt Water Trap
    **Needs repair**
  13. #58
    Vancouver BC
    Seen that horn in person.. NOT LOUD and the tone is very buzzer ish 500hz is a good sound that can travel with being disrupted very easy.. lower the sound the faster it fades into city traffic. 500hz is the sound of a Trumpet playing a good solid mid to high note.
    So Lower then this tone.. more then likely needs a secondary horn.
    350hz http://www.youtube.com/watch?v=vZF_RP5iqIc
    500hz
    http://www.hark.com/clips/ymzlwsfgkc...conds-0db-loop
    I paid about 38$ for my horn
    Do you want help removing your engine and sending it to Rich when I get my box back? sending it should cost less then 65$. It cost me 61$ from Point Roberts WA.
  14. #59
    Sep 2008
    Northern Europe
    Are you going to service your water pump?
  15. #60
    Vancouver BC
    My water pump? not sure.. is there any reason to?
