Page 3 of 13 FirstFirst 12345 ... LastLast
Results 31 to 45 of 181
Thread: PFI Aprilia SR50's
  1. #31
    May 2011
    norway
    Can someone explain what PFI is and how and where the fuel is injected?
    Stock Aprilia Ditech 03 model(Morini)
    Derestricted variator
    6,6g rollers
    molossi powerfilter
    NGK ZMR7AP
  2. #32
    Sep 2008
    Nice weather AT LAST! Winnipeg, MB
    PFI stands for Port Fuel Injection. Fuel is Injected via 1 or 2 Fuel Injectors that are positioned in the TBA (Throttle Body Assembly).
    The fuel injection is controlled via a specially designed ECU that controls when fuel is injected into the TBA.
    Anger is an ugly Mistress…
  3. #33
    apriliaforum expert MeepMeep's Avatar
    Jul 2008
    Mass
    E-mail me. I can't take on anymore work for a few months.
    im glad its picking up, we need 2 of you. I may be looking to go a 180cc conversion but it wouldnt be until after the replica is done anyways......
    2009 SR50R Factory diablo white
    Currently getting the HGT replica WORKS!
    2002 SR50 Ditech Haga SBK replica
    70cc malossi BBK w/ecu
    blue aprilia 7075 ergal bolt kit
    blue aprilia 7075 ergal bar ends
    malossi delta clutch
    malossi reed block
    Aprilia Paoli adjustable shock
    Installed Pussy Magnet
  4. #34
    Parker Colorado
    I would like to get mine all back together also but everyone else's comes first.
    I'm taking a couple months away from College teaching then I will decide if I want to go back. It's a lot of fun and I could do it full time again.
  5. #35
    Sep 2008
    OK, the following pictures show’s what happens when you run a pre-mix T2 engine to lean…
    At first look, I thought that the Cylinder was toast (I knew the Piston had packed it in)… I thought that the Nikasil coating had been worn away. But after sending high res pics to "Dr. Aprilia", he confirmed that it was more a case of the Aluminium from the piston that had been “deposited” on the Cylinder wall. The Nikasil coating is virtually bullet proof and can take a bit of abuse (but it still has its limits of course). So, I picked up a liter of Muriatic Acid to “wash” away the aluminium deposited on the wall. I spent most of Friday looking for a store that had some and while many had it, it came in 4 liter (1 gallon) containers! I needed all of a tablespoon!!!! Finally Canadian Tire had Muriatic Acid in 1 liter containers. So, purchasing the Acid along with a BOAT load of safety items (chemical resistance gloves and brushes, eye protection, a mask, Baking Soda to neutralize the acid, etc), I was all set!
Name:	cylinder damage 1a.JPG
Name:	cylinder damage 4a.JPG
    In many ways, I was lucky. The result was a part of the piston overheating and, in essence, melting a part of itself onto the Cylinder wall. This caused the piston ring to be seated all the way into its track. Then, with the piston “melting”, it sealed it into place.
Name:	Piston damage 1a.JPG
Name:	Piston damage 4a.JPG
    I applied just a drop to the locations with the Aluminium and the clear liquid turned black almost immediately!! A good sign as I knew that when acid comes into contact with Aluminium, it turns the clear liquid black. I waited about 30 seconds, then applied my water and baking soda solution to neutralize the acid. And inspect the work. It removed ALL of the smallest amount of Aluminium and reduced the other spots by at least 50%. So I did 4 more “treatments” and the results are in the picture below…
Name:	After acid treatment 1.JPG
Name:	After acid treatment 2.JPG
    I think that I will do a couple more treatments to get the last of the Aluminium off of the cylinder wall later this week.
    On a good note, I have found a way to get what I needed in order to get back up and running!! If all goes well, I'll have spare Pistons, Cylinder Kit, and hopefully spare Rings and Gaskets in the next 10 to 12 days!!! All thanks to a Member!
  6. #36
    apriliaforum expert NoNameForEver's Avatar
    Sep 2008
    Northern Europe
    Aha! You got yourself a proxy.... Why did you run that new piston/cylinder with a lean mixture, was it by accident?
    Glyptocephalus cynoglossus lover
    Quest for no 3D glasses
  7. #37
    Sep 2008
    Yeah... It was totally my fault.
    The result of a few things... Over exuberant behavior on my part to want to get running, the lack of knowledge in listening to what the engine was “saying” to me and of course, not turning up the Fuel Pressure enough.
    Lack of Fuel pressure in a PFI build means lack of oil to the Cylinder as we run a pre-mix… With a lack of oil, the results are apparent…
  8. #38
    Sep 2008
    Northern Europe
    Quote Originally Posted by Grenadiers View Post
    Over exuberant behavior on my part to want to get running, ......
    Hm.... Could be as a result of hypoxia /altitude sickness after your long stay in Colorado... I would blame it on that..
  9. #39
    Vancouver BC
    a little of both.. into the decompression chamber for you!
  10. #40
    Sep 2008
    LMAO!!
    OK, sounds good! I'll go with that!
  11. #41
    apriliaforum expert captdan's Avatar
    Apr 2010
    Florida
    Greandiers- Did you sand/hone the cylinder at all or is that solely the result of the Muriatic Acid “wash?” Very cool.
    2009 SR50 Factory
    20 mm Bing Throttle Body
    Water Trap (Kobalt tapped with 1/4" NPT brass drain)
    Castrol Power RS TTS
    Castrol Syntec Gear Oil- 75W-90
    Oil Pump Flow Increased
    NGK ZMR7AP-(.030-.032) (Indexed @ 12:00)-
    Leo Vince ZX-R
    Malossi RS24 Rear Shock
    5.0 and 5.5 DP Sliders- Red Springs
    8mm Mirror Risers/Extensions + 30mm Washer
    Aprilia Emulsion Bleed Valve
    LED Tail/Brake Light
    Black Tunnel Covers
    Rear Tire- Pirelli Diablo Performance 140/60P-13
    Front Tire- Pirelli SL 26 Performance 130/60LX-13
    Top Speed (Digidash)-50-51 MPH @ 9100 RPM (Flat Road/Tucked)
    Rider Weight- 215 lbs
    20,200 miles-02/2013
    Yeah, Coulda' Bought A Harley- But Chicks Dig Scooters!!!!!:
  12. #42
    Sep 2008
    Just the Acid only, and only on the Aluminum transfer that was on the cylinder wall.
  13. #43
    Vancouver BC
    Glad you are getting your parts you need! Can not wait to see to see the thing in its natural habitat
    oh and if you have forgot.. Lots of pics and Vids! put that new camera to good use!
  14. #44
    Sep 2008
    That's the plan...
    I have to tell you that the weather here for the last 2 weeks has been just great and the forecast for the next 7 days is sunny with temps between 28 to 31C (today we it 31 with a Humidex of 43c!!) and the road is just calling out to me!!
    This is torture...
  15. #45
    Vancouver BC
    rain rain here... yay
  1. Modifying an Aprilia SR50 CVT
    By Haribolman in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-03-2009, 06:43 PM
  2. Aprilia sr50 ditech..read on ;)
    By Jebediah in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 08-23-2003, 03:07 PM
  3. aprilia sr50 or malaguti phantom?
    By larryep in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 03-03-2003, 12:13 PM
  4. Aprilia SR50 Battery Question????
    By Donjuan7019 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 01-09-2003, 09:02 PM
  5. Driving in my Aprilia sr50 DITECH
    By DITECH rider in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 12-14-2002, 04:24 PM
