Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 38
Thread: stock cylinder/piston limitations...
    Nov 2005
    Lets trough more air with out the disadvantages of an open foamfilter.
    apriliaforum expert apriliamandan's Avatar
    Jan 2012
    England (Cambridgeshire)
    But i would like a more throaty intake noise. The bike isnt going to be a daily commute, just a nice day thrash.
    Ive got an arrow system. Shame nobody knows about the 16mm dellorto carb i have, its got 120 jet which seem huge but is the correct size as it revs out crisply.
    Would like a nice ram air dual stage filter
    Sep 2011
    warrington uk
    just mod the stock airbox and put a polini filter sheet in there, get more power out of stock box anyway and you will still have the deeper sound
    you must of already read why not to buy open/cone/foam/pod filters as it is everywhere on here
    Engine Always Screaming!
    Jan 2012
    Quote Originally Posted by chrism15 View Post
    I havent read anything on them mate tbh, but i realise the downsides of them! However, ive been brought up with bikes with pod filters making throaty sounds!
    Ram air open filters seem to be good http://www.adrenalin-pedstop.co.uk/p...body-4348.aspx
    I would also like some new reed valves for my bike. As yo umay remember its stock apart from derestricted arrow system. What reeds would u reccomend of adrenaline pedstop? thanks
    apriliaforum expert Glen1990's Avatar
    Barrow in furness
    i really dont like the sound of my k&n
    Aprilia rs 50 2000
    Top performance Pink 75cc
    Doppler Endurance crankshaft
    Arrow racing exhaust with carbon endcan
    Dellorto 21mm carb(92 main jet)
    Stock air box modded
    Top performance Cdi
    Malossi reed block 0.30mm
    Conti race clutch kit
    14/47 Gearing
    Mono rear
    Michelin pilot sport tyres
    Rs 125 front master cyilinder
    Malossi upgraded clutch springs
    Rs 125 Headlight
    UPGRADES to come
    24mm mikuni flatside carb
    Double bubble screen
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    Full respray and frame polish
    Doppler air rear shock
    Jan 2012
    Quote Originally Posted by Glen1990 View Post
    Open pod filters sound great, try a ram air
    Nov 2005
    go-Kart filters sound way nicer, deeper sound, not as sharp/high pitched, and makes the bike sound like theres a much bigger engine under there.
    or you can do my airbox mod, wich sounds even better, and is less noisy wen your driving around "normaly"so you dont attract the cops by the side of the road straight away.
    Barrow in furness
    mines a really really deep sound its a loud deep too im not a fan tho stock air box soon anyways
    Aprilia rs 50 2000
    Top performance Cdi
    14/47 Gearing
    Mono rear
    Rs 125 Headlight
    UPGRADES to come
    Yasuni R3 exhaust
    Gear indicator
    Custom rearsets
    Sep 2011
    warrington uk
    open/pod/foam/cone air filters let in more air than is needed so you have to upjet to near 100 in dellorto jet sizes to match the amount of air and theres no major performance gain from them.
    for road use espically they are crap, in heavy rain they can draw in moisture and worst come to worst in cud make its way through the carb and end up in the crankcases and ruin your crank bearings ect leaving you needing a bottom end re-build but the engine probly wud die before it got to that - and if the foam filters get wet they can starve your engine of air making you break down
    just mod the airbox using patricks airbox mod and put a polini air filter sheet for stock box in, you will here a slightly deeper sound from this polini sheet
    http://www.adrenalin-pedstop.co.uk/p..._cut-3185.aspx
    apriliaforum Junkie Holfy's Avatar
    Feb 2012
    United Kingdom
    what is this airbox mod is there a thread on it anywhere ???
    Nov 2005
    Airfilter doesnt make much difrence, i had the Polini my self, also had a Malossi (precut) wich i liked much better, and now i got a cheap black filter element in there wich looks exactly like the Red Malossi filter in structure and seems to perform the same.
    Sep 2011
    warrington uk
    Quote Originally Posted by Holfy View Post
    yerr there was a thread on it but last time i looked i couldnt find it! il look again now and if i find it il edit this reply
    patricks mod is somewhere in this thread:
    http://www.apriliaforum.com/forums/s...ght=airbox+mod
    but there was another thread purely on rs 50 airbox mods, one
    GOT IT
    http://www.apriliaforum.com/forums/s...ht=air+box+mod
  13. #28
    Feb 2012
    United Kingdom
    ok yes please would be nice to have a read up on it do you not think you would get better air flow if you cut the standard inlet rubber so it is straight instead of it bending up in the airbox
  14. #29
    Sep 2011
    warrington uk
    "reply edited"
  15. #30
    Jan 2012
    Ill take time reading the stock box modding. BTW im running a 120 jet size anyway lol its stock for the 16mm dellorto
