Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: Chain tension question
    Apr 2010
    San Francisco
    Thanks for the details folks. Gives me something to go on with. The guy who adjusted the chain used a laser which he seated against the rear sprocket. So in reality the adjustment hinges on the accuracy of the rear sprocket. As I mentioned in the original post, this meant the tick marks were out by two, and just looked odd.
    On a positive note, on the ride home the bike turned left pretty quick. I'll give it some attension this weekend and see if I can get it straight.
    apriliaforum expert jmardy's Avatar
    Jun 2011
    San Rafael, California
    Serious about the offer. PM me if you feel like coming to San Rafael.
    Marin County, California
    2005 Tuono Factory
    Likes Marin Moto Works
    SaferMoto
    RIP Kenny The Iceman #12
    Apr 2010
    San Francisco
    Thanks, I appreciate the offer. I'm busy this long weekend, but could make it up next sunday. Let me know if that suits.
    Jun 2011
    Quote Originally Posted by MrP View Post
    Almost any weekend/evening.
    2005 Tuono Factory
    SaferMoto
    Aug 2011
    3rd rock from the sun
    Even with a perfect sprocket, this method won't work reliably on any bike with a cush drive on the rear wheel.
    Jul 2011
    Flo Rida
    Quote Originally Posted by Galaxian View Post
    Of all bikes with cush-drive, the RSVR/Tuono seems to have the most accurate/tightest interlocking fittings (I can't say that among some of the Suzuki's I've owned - very sloppy). But even if that, the cush-drive hub has it's own set of bearings which should keep it perpendicular on the axel regardless. Torque and acceleration should not be distorting that align under load as the cush mechanism should only allow for twist variances. Therefore, I bet one could yes indeed get a reliable "good enough already" alignment while the wheel is mounted. While it is mechanically very important to have good sprocket/chain alignment for sure, but.... I think these types of threads seem to over-analyze to the point of anal retention on alignment perfection, i.e. I don't think substantially more wear is going to occur given a hash-mark or two being off, let's say as opposed to variances in light/hard riding conditions, and lubrication/maintenance intervals. But if you all enjoy such topics, can I point you to this alignment thread for a much deeper look.
    Aug 2011
    I should have been more specific.
    Using the rear sprocket to get proper wheel alignment (which is what you should be after, not chain alignment) on ANY bike, particularly one with with a cush drive is not the right way to do it. There are other, more reliable methods.
    Mar 2007
    Palos Verdes Est. SoCal
    Wink alignment?
    you want the centerlines of 2 wheels and the steering head in the same vertical plane, period.....
    thats for handling....
    for chain/sprocket life you want the rear sprocket directly behind the C/S sprocket....
    misaligned sprockets are a horsepower loss, look it up in any engineering book or power transmission book
    after carefully measuring the chain line/case centerline relationship Aprilia doesn't seem to care......its an strange number
    my chain aligns perfectly.....with the cutout on the inside....opposite of stock
    aligning the rear axle to the swingarm pivot is a fools exercise regardless of what tool you use.....because you want the wheels aligned, who gives a shit where the pivot is......you can't do anything about it
    look at all the BS in the cush drive......ball bearings? for what? a couple of degrees of movement? hey, Yamahas use needle bearings.....for all that high speed movement, right?
    put a nylon sleeve in there......when you race 3,000mi a day
    http://t2.gstatic.com/images?q=tbn:A...4_LZvXItJ29XcQ
    http://t2.gstatic.com/images?q=tbn:A..._PxMEsjpPMCjPg
    good old #7 'the Freight Train'
    on the back cover of every European Bike magazine for years
    on the steering head:
    EK900R
    H407Y
    the H&Y are the 1st and last letters of my last name, yes, i made the bitch
    Seppi Arnold, the workshop boss on the cover of the Egli catalog on his HRS 812 Egli Honda.....every bolt is hollow, the Mg wheels are shaved too
    http://t3.gstatic.com/images?q=tbn:A...CylDWysEjk9uYy
    Noel-theknurl
    The Forum Curmudgeon
    I'm not PC either
    ph. 310-540-4823 PST, GMT -8
