A more serious note, that leak would have me concerned ...
Glyptocephalus cynoglossus lover
Quest for no 3D glasses
CMRA #728 Novice
2006 GSXR 600
http://www.scracecenter.com/
2007 SR50 Factory:
Malossi 70cc Kit, ECU
Full Circle Racing Crank,
MHR pipe, White Spring
7g Dr Pulley Sliders
1964 Vespa:
133c/4spd conversion
I don't see any other option than to pull and inspect if you want to solve this.. And use the correct torque.. Are you sure you didn't strip any of the threads?
Yeah pretty sure.
Is there an easier way to drain the gas tank than pulling the injector lines?
CMRA #728 Novice
2006 GSXR 600
2007 SR50 Factory:
1964 Vespa:
Get a hand crank gas tank pump.
#1 Forum Loser
Can I use something like this in with the O ring water seal in the head?
http://www.oreillyauto.com/site/c/de...2362&ppt=C1984
Used it on the vespa trans since the paper gasket kept leaking, and it worked like a champ.
CMRA #728 Novice
2006 GSXR 600
2007 SR50 Factory:
1964 Vespa:
Make sure it isn't trickling down off the thermostat housing.
Ok pulled the head without pulling the motor.
I should have taken pictures but I pulled the access panel to the battery.
Popped off the Coolant lines and drained them into a can.
Accessed the FI cluster from the battery area. Loosen those 2 bolts.
Unplug the 2 connectors and pull the head while it is still in the scoot.
1/4inch drives, 3/8 drives with multiple extensions will be needed.
I could even get my 1/4inch tq wrench on the bolts afterwards.
The very bottom of the seal got pinched. Got it fixed with some sealant and the old gasket was in good shape still.
CMRA #728 Novice
2006 GSXR 600
2007 SR50 Factory:
1964 Vespa:
