Results 1 to 6 of 6
Thread: cvt fully transitioned speed
    May 2005
    Jonesborough, TN
    After looking at HGT dyno graphs I believe the speed at full transition is 45mph with stock gears, tire size and variator. With a Malossi gear up kit that should raise it to 52-55mph. With a 150X70X13 rear tire it should be 56-59 as far as my math goes but I have reached a verified 63mph and never got the rpm to increase like it would if the variator was fully transitioned. I need to know the ratio of the Malossi gear up kit
    and is the variator a 1 to 1 when fully transitioned? The stock tire is 19.25" tall and the 150X70X13 is 21" tall. Any math people out there than can figure this?
    2003 Ditech Malossi BBK, top speed 65mph (GPS)
    apriliaforum expert Alexandar's Avatar
    May 2011
    Skopje, Macedonia
    if i understand you good you just need to divide the tooths for example the one i use is 14/39 which ratio is 2.78, but those are primary and you will have to know the secondary gear ratio or how many tooths they have.........its a but complicated
    google Getriebeberechnung EN its a calculator......
    SR DiTech Piaggio c361 2005
    Polini Kit 70cc
    Polini Bowl
    Malossi Multivar 2000
    Original Piaggio Contra Spring
    Rollers Malossi HT 7.5 grams
    Malossi Special Belt
    Malossi Oil 7.3 & Agip City 2T
    Malossi Gears HTQ 14/39
    Gianelli Reverse
    Air Diffuser 20mm
    Clutch Stage6 Torque Control MKII
    RMS Crank
    Woodruff Key 3degrees
    Malossi Air Filter
    Polini Carbon Reeds 0.35
    Water Trap
    Fuel Pump Mod
    Ecu Derestricted version 2.8.0
    Spark Plug NGK ZMR7AP
    Sava MC 29 Sporty 3+
    Lights Philips Master LED spot LV 10wx2
    Brembo brake pads
    May 2005
    Jonesborough, TN
    Well after playing with my calculator for a while this is what I came up with. At 1000 rear wheel RPM with 150X70X13 tire the speed is 62.5 mph. Not really sure what the engine RPM is at this speed. I need to get a tach bad. I'm thinking 8000 rpm or so.
    May 2011
    Skopje, Macedonia
    Polini Kit 70cc
    Polini Bowl
    Gianelli Reverse
    Air Diffuser 20mm
    RMS Crank
    Malossi Air Filter
    Water Trap
    Fuel Pump Mod
    Brembo brake pads
    Parker Colorado
    Quote Originally Posted by jre200 View Post
    You may be looking at Piaggio Dyno graphs. The Morini has a very large rear fixed pulley system and can hit some very high top speeds. I have a much different engine in mine but the gears are stock and it has a 73mph on the dash right now.
    May 2005
    Jonesborough, TN
    Rich, that would mean your rear wheel speed is 1260 rpm. To go that speed you must be fully transitioned and gaining speed through increased rpm? I'm trying to figure at what speed should I be fully transitioned. So far I don't think I have been able to reach that speed.
