Results 1 to 15 of 17
Thread: dies while riding
    May 2012
    fairfield,ca
    dies while riding
    I have a 03 fut love this bike never had a problem until today. While riding the bike dies (just like it was switched off). Pulled over re start ride dies again. when it is running feels and sounds normal. Any ideas ?????? Thanks in advance
    Sweden, Germany
    Sidestand switch perhaps
    apriliaforum expert flying fox's Avatar
    Apr 2008
    Stockton-on-Tees,UK
    Had this happen twice ;
    1st was the fuel pump relay,situated next to the oil filler,on the frame rail.As you look at the bike,there are four relays,two of which are the same.The one on the right powers the fuel pump.If you don't hear a whine from the tank when you turn on the ignition,it is probably this relay at fault.
    2nd was the tilt switch - designed to kill the engine if the bike leans over more than a predetermined amount,ie:when it falls over.It is situated behind the clocks.
    BTW - WAFO!
    04 Silver,Derestrict Airbox,Mille Boot,Reg/Rec Mod.,05 Map,Heated Grips,Smoked Screen,Beftura Forks,HID Headlight,Stone Chips,Scratches...
    Where there is a will...There is usually a dead relative!
    The Art of Bodge-It Never Fails.
    PA USA
    And let's not forget about that connection in the loom behind the right radiator.
    Apr 2008
    Stockton-on-Tees,UK
    O.K. - so that was 3rd!
    apriliaforum expert Prilliant03's Avatar
    Nov 2003
    Plymouth, Devon, England
    Also check the killswitch. When my RSV started cutting out at speed it was due to water ingress at the right hand switchgear.
    "Life is like a sewer. You only get out of it what you put in."
    Tom Lehrer.
    Nov 2003
    Derbyshire England
    also the key.
    when it dies, does the dash go out as well
    or just the engine stops?
    if just the engine stops then could be many things. mostly mentioned above.
    if the dash dies as well look at the key switch.
    bullit
    Pilot Roads 2CT, H-PIPE, BEF's, Touno forks and a Wilbers Rear end, R&G FRame sliders, Rhino barend sliders, RhinoMoto front axle sliders,(thats a hole lota sliding to be done)MILLE BOOT, K&N, HID's LED running light , Heated Grips, Double bubble(now removed) and a whole lot of attitude.and renault coils.
    apriliaforum expert Twinz's Avatar
    Aug 2008
    Montpelier, VT
    My bike died once on my recent trip...of course on a tiny twisty road in the middle of nowhere! It wouldn't restart until it cooled a bit...engine would crank but not catch...on a dry day. It only happened once but left me feeling less confident in the bike. Since I've checked a number of things, I will go after the right side harness issue probably next winter unless it happens again. I don't remember what the dash did except I think it acted normally.
    Twinz - John
    Montpelier, VT
    '04 Fut Ash Black...de-restricted, Evo air filter, Bikpaintr re-rectified, Dingledork bungeed, QDs, RKA tankbag, Powerlet, Heattroller, waterproofed coils w/Stu_O HT wires, R&G sliders, Skidmarx hugger, Fenda-extenda, Bungee Buddies, Scottoiler (removed), Heli-Bars, Heaterz grips, Staintunes, Stebel Nautilus, Fuzeblock, Zumo 660, Acumen DGV, rebuilt forks w/Ohlins valves & RaceTech springs, Bef's R&G bar ends.
    '94 BMW R1100RS...sadly sold.
    '73 Guzzi V7 Sport...sold - that was dumb!
    '80 Guzzi V50II...when all else fails
    PA USA
    about 4/5 years ago, i spent the whole summer not knowing wtf the thing would do every time shut it off and then tried to restart. Bypassing the sidestand switch and cleaning up some other connectors fixed it.
    Aug 2008
    Montpelier, VT
    I had already bypassed the sidestand switch and the tipover switch worked when I dropped the bike last spring due to clutch not disengaging. I did go over all connectors two winters ago but haven't looked at the harness yet. The bike performed flawlessly in heavy rain on the slab...and that made me happy!
    Twinz - John
    Montpelier, VT
    Sweden, Germany
    Quote Originally Posted by Twinz View Post
    Just make a small hole at the lowest point of the sheath behing the RH cooler.
    If water and stuff comes out you know you will have problems reocurring.
    I have two cables with me which I can power the fuel pump directly from the battery if needed.
    Aug 2008
    Montpelier, VT
    Sounds like a very smart idea! I do carry a spare fuel pump relay but the bike started before I had a chance to listen for fuel pump whirr at key-on.
    Twinz - John
    Montpelier, VT
    May 2012
    fairfield,ca
    I am on the road again Thanks too all, Deefred hit it on the head. Bypassed the stand switch all is good!!Thanks again Mark!!!
    Nov 2003
    Excellent news. There can't be many long term Aprilia owners who haven't suffered at the hands of a failing side stand switch. Makes me wonder if there wouldn't be a market for some inventive chap to make a reliable replacement. I know I would buy one.
    Tom Lehrer.
    apriliaforum expert Powerful Pierre's Avatar
    Nottingham, UK
    Quote Originally Posted by Prilliant03 View Post
    I've got one! An option offered by Ultimate Parts after 2 of the original type failed over the years (they always seem to crack in the same place and let water in)...........just checked it prior to trip starting next week and its still looking good.
