Hi all,
I saw a sxv on ebay with CRG levers. I called CRG and they said they don't make them for sxv's.
I don't see them listed for ASV levers either. What will fit and where do I get them?
Thanks, Randy.
Hi all,
Thanks, Randy.
Nobody makes levers that fits the xv's, or so they say...
http://www.apriliaforum.com/forums/s...r-Worth-Having
Only if we understand...can we conceive of the paradoxical phenomenon that people who are afraid of living are also especially frightened of death.
I hate Murphy
The asv f3 pro for the honda crf, with the stock clutch theres no problem theres enough room to adjust cable tension, with the adige slipper it took some bodging!!! just make sure its well lubricated a lot of people on here has had problems with snapping cables when using aftermarket levers.
i use lithium grease on the cable nib in the lever, and a ptfe lubricant for the cable using a cable oiler. 800km and still going strong and 1 finger smooth!!
sxv 450 2009
ktm 660 2003
The model is CMF33-SK, this is for a shorty black lever. I have this same lever, you do need a barrel extender because the clutch cable is to long and it doest not provide enough tension. Contact asv and they will send you one for free. Lever works flawless except for the lil nut in the back of the lever touches the light switch, all you have to do is remove it and you have a bit more room when you pull the clutch. Only negative i can find at least for me anyway is the the point of engagement is literally less then 1/4 inch from bar.
He is talking about this gu:
http://cgi.ebay.com/ebaymotors/April...76682920#v4-41
he's got crg levers on it. I can tell he's running a sportbike clutch perch but the front brake lever is also crg but appears to be stock master cylinder
The response I got was the previous owner was a machinist. Well dang, I'd like to meet that guy! Someone should ask for a more detailed photo!
If I had an excuse to head his way, I'd just visit the guy since he is 2 hours away.
I'll buy the the beer!
But seriously that seems like a good price. Ya think?
I have the ASV clutch lever with the oem cable and it works fine. http://www.apriliaforum.com/forums/s...ight=asv+lever
ASV does NOT make a front brake lever for the SXV. As of this date, I'm certain nobody still does. The ASV fits the clutch because the sxv/rxv clutch perch is basically a universal design shared by many. However, the RXV front brake is of similiar design shared by many, so you can find levers for the rxv.
kooLaid, I spoke with someone at CRG and sent that link with the pics.
They said they would look into it for me.
I will post any findings.
Randy.
