Results 16 to 30 of 33
Thread: New front brakes
    Nov 2008
    Colorado USA
    Sometimes what feels like a warped rotor is pad material build up on the rotor. This can happen when you change pad brands or compounds even within the same brand.
    To fix you need a simple hone and a power drill - take the rotors off the wheel, hone both sides removing the built up pad material then re-install using loctitie on the rotor bolts.
    Then bed in the new pads properly - (according to the manufacturer's recommendation)
    I would say 8 out of 10 "warped rotor" complaints I've heard on motorcycles have been solved by this kind of maintenance.
    S
    apriliaforum Member dmartin's Avatar
    Calgary, AB
    well i'm glad i kept my old rotors after replacing them last week and reading this now. they are probably just as good as the new ones haha. o well. live n learn.
    ______________________________
    2005 Aprilia RSVR 1000
    2009 Ducati 848
    2005 GSXR 1000
    2006 GSXR 600 Track
    Oct 2011
    canada
    i honed mine before i put them back on. i did not change out the pads at the time because there should be no issues a 7000km.
    apriliaforum Member fzwilly's Avatar
    Nov 2010
    massachussetts
    I have this same condition on my Tuono factory and thought it might be the pads. I was feeling a slight pulse especially at slow speeds but recently I was tearing up the canyons and found breaking from 75 mph + I felt like the front end was going to shake off. I think the OP is right about the mfg correcting the design so this can't occur so easily. I've never had this happen on any other bike I've own especially my 06 FZ1 with 45K and I ride both bike equally as hard. BTW the pics on the link someone posted with the fix were just "X"'s
    Oct 2011
    canada
    i havnt seen them yet so they may not look exactly like this.. but my EBC prolite rotors are in and i get to pick them up tomorrow. hopefully i will have time to instal them and my new EBC HH pads tomorrow night!!
    *edit*... EBC sent the prolite on accident, i had ordered the OEM ones... so i got the pro lites for 189.99
    apriliaforum expert asb2106's Avatar
    May 2010
    Kenosha WI
    do you by chance have the model number for the pro lite? Just wondering what it is. thanks!
    apriliaforum expert wrx_02's Avatar
    Nov 2008
    Fort Worth Texas
    Quote Originally Posted by rybo View Post
    S
    Bingo!
    http://www.sears.com/shc/s/p_10153_12605_SPM209904580P
    Bought one of these and made the difference. Swapping brakes/compounds can cause issues.
    CMRA #728 Novice
    2006 GSXR 600
    http://www.scracecenter.com/
    2007 SR50 Factory:
    Malossi 70cc Kit, ECU
    Full Circle Racing Crank,
    MHR pipe, White Spring
    7g Dr Pulley Sliders
    1964 Vespa:
    133c/4spd conversion
    Oct 2011
    canada
    Quote Originally Posted by asb2106 View Post
    I can get it when I pick them up from 613motorsports on sat.
    Quote Originally Posted by wrx_02 View Post
    Bingo!
    I did that once already. As well as cleaned everything and followed the button mod instructions.
    apriliaforum newb Wharewolf's Avatar
    Jun 2009
    good to know when that time comes. Will definetly try to clean old ones before purchasing new ones.
    03 Bonneville
    08 R1
    09 RSV R
    If you measure the rotors with a dial indicator you will see that they are not warped much if at all (measure run out with wheels/rotors on the bike).
    Especially when the service manual states that acceptable limit for front rotor runout is 0.3mm (I prefer 0.1mm myself).
    This is indeed a very common problem and is not caused by the rotors being warped, or the buttons that need cleaning or loosening.
    The only long term solution is to replace the rotors.
    I recommend buying thicker rotors (stock is 4.5mm) and use round rotors not the wavy rotors.
    Some wave rotors are extreme, others like the EBC are less wavy and work OK.
    But round rotors work best.
    Oct 2011
    canada
    here is the part number for ASB
    i got sent out of the country for work. so i didnt even get to pick the rotors up until today. hopefully going to install them tomorrow night.
    May 2010
    Kenosha WI
    oh they look great! Thanks for PN
    Something often overlooked with pulsing brakes is the variation in thickness of the disc as it passes the caliper. With a micrometer - not a caliper - measure thickness around the full circle of the disc but at fixed distances from the edge.
    A difference as little as 0.0005" (yes that's 5 ten thousandths) can be be felt and is barely tolerable. I have measured early Mille discs with 0.002" variation and it pulsed so bad it blurred the vision and was, for all intents and purposes, unrideable.
    Variation in thickness as the disc passes the caliper is much more troublesome than mere runout.
    apriliaforum expert VR-8's Avatar
    May 2005
    Sweden
    This is what you need for racing.....at a resonable cost.
    M4 Brembo calipers
    BrakeTech rotors, I chose the AXIS/SBK 320x6.5mm, get the Cobra or regular Iron discs.......the feel is second to NONE. Direct contact rotor/disc is unpresidented.
    Ferodo ZRAC pads
    Keep stock master or go with RCS/forged......it's up to you.
    /J
    May 2005
    Sweden
    This is why I know.........
    My recent setup on my supercharged Ducati 1098S (204rwhp) was incredibele and still is.....
    /J
