Thread: Rs125 Problem... Please help!
    May 2012
    Northampton
    Hello, i have recently purchased a rs125 fp all original, and great condition with only 3000km on the clocks. Me and my dad have took all fairings off and cleaned it till our fingers bleed. But after we put fresh petrol in, new battery decided to give it a run... Started her up good as gold running fine all warm up gave it a couple of revs, still fine got on engine temp at 80 went to pull off and it just bogs down. Since this we have stripped and cleaned the carb, changed the plug but it is still doing the same thing. Was just wondering if anyone has any ideas as to what else it could be anything would be helpful. Thanks
    apriliaforum Member Draftpunk's Avatar
    Jul 2011
    Sunshine Coast, Australia
    Probably the same problem I had. Side stand switch not working (if you have one). Check to see if you've plugged it back in.
    mate
    2010 RS125 Gloss Black
    Arrow Exhaust (E Marked) | Moto Tassinari vForce3 Reed Block
    2002 SR50 Morini Ditech Matte Black SBK Replica 50cc
    Leo Vince GP can | 68cc Kit (Malossi) | Full Circle Crank (Malossi MHR HPC) | Primary gear kit (Malossi) | vForce2 reed block (Top Performances\Moto Tassinari) | 19mm bored throttle body
    2002 SR50 Morini Ditech blue 50cc FOR SALE (daily rider) 100aprilias/hr (80km/h)
    ECU "development mode" (apparently) | 19mm bored TB | Carbon reeds | Std. Variator | 6.0g Rollers [slightly heavy but good] (Malossi) | Std. Clutch | Red Contra Spring [Racing] (Malossi) | Blue Clutch Springs [Sport] (Malossi) | Custom Water Trap
    Aug 2009
    Are you only riding it down the street and than brining it right back? You need to ride it for a few minutes and clean it out after warming it up and letting it idle etc. It's like that every single time i go riding. Bogged right down at the start but wind it out a few times (high revs) and it'll come to life.
