Results 16 to 30 of 60
Thread: LEOVINCE ZX-R Roller weights
    May 2012
    NA
    If I can find that Makita I will be getting that... if not, I will look for the locking tool... anybody recommend a specific kind and where to buy from?
    Vancouver BC
    I can fins the link when I am home for you.
    Parker Colorado
    Quote Originally Posted by Snugg View Post
    When you do ruin that crank shaft, please PM me. I would be happy to install the new setup for you at a discounted price of $900.00
    Vancouver BC
    That is hilarious!
    Parker Colorado
    That's going to be the basis for my DiTech shop labor rate sign.
    Vancouver BC
    Good thing I'm not driving to Denver now.. It would cost me a fortune
    apriliaforum expert wildchild's Avatar
    Oct 2009
    Orange County, CA
    To purchase the necessary tools is a a good way to prevent doing any damage to parts. I find I use the tools more often than not. It also makes it a breeze to maintain and modify. I have damages parts by not using the proper tools or torque specs. So I can say I've been there. Good luck on your purchases. You can also find used quality tools. A second option. Just need to do some homework.
    Being upgraded SR70
    2009 SR50 Factory
    De-Restricted. Version 2.8.0
    Leo Vince
    NGK ZMR7AP 10mm ind. wshr. HGT brake levers
    HGT Regulator @ 110psi.
    Malossi "Red" Sponge Filter, Modified Air Box
    Malossi multivar 2000 rollers. White contra.
    Custom Lisc. brakt. Custom.
    rear shock, HG Black brake levers
    3 deg.woodruff key/Kobalt water trap
    2009 SR50 Factory White. Derestricted. 2.8.0
    ZX exhaust heat wrapped black. 6,5 rollers
    Ngk-ZMR7AP indexed. White contra Custom Lisc.brkt. 3 degree woodruff
    HGT Gen.II fuel reg.
    May 2012
    NA
    Quote Originally Posted by wildchild View Post
    Thanks... I agree.. I have used cheap screwdrivers before, and just stripped screws... not worth it in the end. I am trying to gather as much advice from you guys as possible... will help me in the long run
    Vancouver BC
    Better to start right the first time.. saves you a TON of money
    apriliaforum Member dfxdig's Avatar
    May 2010
    myrtle beach, sc
    op, don't use an impact gun. get the right tools from hgt. although i didnt see them on his site last week, i would suppose he'd get them for you. the front variator and clutch holding tools i got from him were inexspensive and of good quality. believe me when i say that when the fever hits, you'll use'em more than a few times.
    2010 sr50 factory
    piaggio motor
    ecu- 2.8.0
    plate and ring removed
    zx-r exaust, woodruff key
    delta clutch, molassi tc
    molassi torque drive
    pod filter, v13 reeds
    agip city 2t
    1000 miles
    water trap
    gen III hgt fuel reg
    multivar 2000
    May 2012
    NA
    Quote Originally Posted by dfxdig
    thank you... would hgt be able to send me a link? id like to buy
    Vancouver BC
    He had stopped supply because of a bad dealer to him. I can find you a link hopefully
    Vancouver BC
    Here is the Tool you need.
    Variator Blocking Tool
    This is a All in one tool I just found.
    Clutch/Vari Holding tool
    I have not used the second link so I can not say how strong or if it would be suitable for this setup. The First link I have and works wonders and is small and fits under the seat or above the battery
    Banned Snugg's Avatar
    Aug 2007
    Aurora, CO
    I have the tools, I have yet to use them though
    May 2012
    NA
    Quote Originally Posted by Rosscofat
    thank you so much
