Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: Mille engine vibration 6000rpm and above.
    Aug 2007
    Incontinental Europe
    The tach needle is just pressed onto a metal shaft. Take your clocks apart and reset it to zero. Make sure it is properly pushed onto the the shaft, because they are known to slip sometimes when not properly installed. That is what has probably happened to yours.
    apriliaforum expert cew's Avatar
    Jun 2010
    Brandon, MS
    Quote Originally Posted by RSVRThumper View Post
    @danv990- tach needle is off. I used a digital handheld tach and it's idling at 1100, but showing approx 800 on the tach. When the key is turned on it only swings to 56-5700. I'm gonna have to research the issue. Sorry for the bad info guys! Never would have thought my tach was off. I shouldve know better with those numbers!
    Wow, I never imagined the tach being off that much. It would be bad if someone were to consistently take it to redline according to an erroneous tach and find out he surpassed the max rpm by a couple hundred......every time. I am going to check my tach soon.
    The rev limiter will still function no matter what the tach says.
    apriliaforum prov-nov RSVRThumper's Avatar
    Apr 2012
    Southern PA
    That explains why my rev limiter hits a little early too... Total shocker to me. Glad we got on the subject!
    apriliaforum expert Wot_bike_isit's Avatar
    Santa Barbara CA USA
    Said you replaced the chain...is it set correctly. Slack and alignment?
    I had set the chain too tight on my falco ( with a rsv swinger) and was getting a heavy vibe mid rpms. I actually was able to see the chain where it passes through the swing arm vibrate from side to side right around 6k rpm . Slacked it off and gone.
    25mm of free play on the side stand is what you want.
    "The medium girls over there......It is a disaster!"
    Rossi
    "For me ees niice...no problem!"
    Cappirossi
    Jul 2011
    Santa Cruz, Ca.
    Just wondering is it actually a vibration or is the engine surging? Recently I took Kz's advice and started wearing ear plugs and found it incredibly easy now to play in the 5,500-9,500 rpm Range. Anyways.... A CHP riding on my ass two days ago had me holding a steady 6,500 rpm for a couple miles (Ok,... so I was taunting him ) I noticed a faint steady engine surge. I had mistaken it for vibration before.?
    Mar 2012
    Wellingborough UK
    Hi guys. Sorry for not posting any replies recently (working away, and missing my 'prila).
    I balanced the TBs and is better but the vib is still there. The chain tension is around 25mm on the side stand. I will check the rear whel alignment coz the adjuster markers ain't he most accurate.
    I did have the bike dyno'd and gave a respectable 117bhp and 70lbs torque.
    Many thanks for all the ideas, there's some on here that I will still try out to smoth it all out.
    Oct 2011
    Valley Center California USA
    Quote Originally Posted by Sir James View Post
    Idles at 1400rpm? I'm a newbie too, mine idles around 600, just above the small hash marks on the rpm guage. Is that too low?
    I just realized today that I was reading my engine RPM's wrong. On the Tach, the lowest reading is 1000 rpm. so just past the hash marks actually reads about 1600 rpm's, not 600. Is that correct?
    Jun 2012
    uk
    mine vibrates at about the same revs but just sounds like keys rattling in ignition but its not that as i have held the key with one hand while riding and its still there !! very annoying and i will find it one day but god nows what it is !!!!
    Stroudsburg, PA
    That is correct.
    The shot below shows my bike idling at around 1,450 RPM
