Page 1 of 3 123 LastLast
Results 1 to 15 of 45
Thread: Conflicting advice, please help (Oil question)
    Apr 2012
    Australia
    Hi all,
    I've been told constantly throughout my riding life that engines need a semi-synthetic oil to run-in properly.
    I asked my Aprilia dealer what oil I should use to do an oil change pre-1000km service (around 20-200 kilometers).
    The guy said Aprilia has told him Motul 300V (which is a fully synthetic oil, as far as I know), which makes no sense to me. He said it didn't to him either, but he asked 3 times to make sure, and they still said Motul 300V. Apparently other oil takes too long to heat up and can 'damage the cam chain tensioners'.
    Sorry if I have missed something obvious, but I would really like someone who knows (definitely) to point me in the right direction.
    Thanks guys, much appreciated.
    apriliaforum Member Rayzor61's Avatar
    Jan 2010
    Yardley, PA USA
    Maybe they consider being run-in anything above the first required service (625 miles) and thats what your service guy is going by.
    The owners maual also suggests burning 95 octane too; whats that?
    Mine goes in next week and I wonder if I have a say as to what oil they dump in mine? I doubt they have that Amig in stock.....
    TRIUMPH NUTHEAD, APRILIA NEWBIE!
    Current Stable
    2012 Triumph Tiger Explorer 1200 - Main Rider
    2009 Tuono Orange Crush - For Sale
    Previous Kickers:
    2011 Aprilia Shiver
    2012 Tuono V4R
    2009 Aprilia Mana 850
    2009 Harley Street Glide
    2009 Suzuki DRZ 400S
    2011 Ducati Multi S Touring
    2007 V2 Tuono Dialblo Black
    2002 - 2007 Triumph Speed triples (6)
    2008 Triumph Scrambler
    2010 Triumph Thunderbird
    2010 Triumph Tiger 1050
    1979 to Current - Triumphs entire Lineup since 1979
    2010 KTM Adventure R
    KTM Supermoto 950 R
    The list goes on!
    apriliaforum Junkie hdtech's Avatar
    Jan 2012
    Gold coast, Australia
    Quote Originally Posted by rocky View Post
    Hi all,
    Hey Rocky, A lot of high end bikes come out from the factory with synthetic oils. These oils have better lubricating abilities and cleaning additives. They work better on newer vehicles due to the structure of the metals/materials because they are less porous. Older engines from say the 70's for example had very porous cases/ gaskets and looser machining tolerances which a synthetic oil will seep thru or blow by. Newer engines have less porous metals and tighter machined tolerances need a oil which can get into these tighter spaces and be able to handle the higher pressures and temps.
    In short I recommend running a good synthetic oil in any high performance new vehicle. I run the Motul 300v 15w50 in my 2012 RSV4 Factory. I'm also a mechanic btw.
    Cheers,
    Justin
    Apr 2012
    Australia
    Quote Originally Posted by hdtech View Post
    Cheers,
    Justin
    Justin,
    Thank you mate, that's fantastic information. I can now make sense of the information provided by Aprilia.
    I hope the bike is provided to me with something similar to 300v.
    Thanks again
    New Braunfels, TX
    Agip 5w40 full syn comes in them from the factory, and is what we recommend to keep using
    lots of cars also come with full syn in them from factory, all Ferraris, Porsches, and Corvettes to name a few.
    Ed Cook AF1 ed@af1racing.com
    AF1 Racing Online Store
    Jan 2012
    Justin,
    Thanks again
    Now worries Rocky, oh and what part of oz do you live in?
    apriliaforum expert potere's Avatar
    Oct 2010
    Monterey CA
    I have an additional perspective to add because I'm a chemist. The synthetic oils are better because they flow better at low temps and because they resist tearing (shearing) at high temps. These properties are the main reason a syn oil is superior. If you were an engine, which would you prefer?
    Synthetics will flow at temps so low, a semi-synthetic will be a gel and a non-syn will be a block of ice. Longer chains of oil molecules equals better surface coverage. The syn's maintain that longer chain much longer than non-syns. Oil molecules are literally being ripped to pieces in the heat of an engine. More coverage of parts equals, you guessed it, less wear. Additives are additives. There are better ones today than ever no matter whether syn or non-syn. Same chemicals go into both in the same amounts.
    None of this means squat if you don't change your oil religiously. The damage done by 1 missed oil-change is there forever. I change my oil before it's due and before every track day.
    potere - italian for power
    have M1 permit, will travel
    Auckland, New Zealand
    Quote Originally Posted by Rayzor61 View Post
    The owners maual also suggests burning 95 octane too; whats that?.....
    Not sure if you were serious... but just in case...
    95 octane is referring to the octane of the fuel. Dont run an 89 or 91 rated fuel. Use 95 or more.... low octane in these motors can cause pinging and be BAD
    ScottyDog
    Linkage Tester !
    In The Garage
    1. Tuono V4 in super fast Yellow, 15/42, Werkes pipe, Race ECU, Oz Forged Wheels, Aprilia Touring Screen, Revalved Forks & Shock, heated grips, CRG Bar End mirrors, Ventura Rack, Carbon side fairings, Baher Intercom, Mana raised bars, Nitrous kit, super charger, shitty Chinese folding levers & a sticker that apparently makes me ride faster and a sore ass from the marginal seat...
    2. RSV Factory 2007 With full Carbon Fibre Fairings and other flashy shit. For sale if you're interested!
    3. GSXR750 K7 Track bike
    apriliaforum Member standrewscross's Avatar
    Jan 2012
    Melbourne, Australia
    I was told only to run 98, noting it will run fine on 95 but any reason you would use 95 except for not having 98 available?
    Jan 2010
    Yardley, PA USA
    The highest octane we have in my area (North Eastern USA) is Shell 93, there may be some Sunoco's that have 94. I just got a Triumph Tiger and the set-up mechanic (freah outta Triumph school) said they dont fill their new bikes up with hi-Octane because noboy buys it and it sits in the undergroud tank and collects moisture; the lower octance is fresher.....
    .....I havn't used anything in my Tuono but the Shell 93....no pinging or popping so far...Whata you think?
    Current Stable
    Previous Kickers:
    2011 Aprilia Shiver
    2012 Tuono V4R
    KTM Supermoto 950 R
    The list goes on!
    New Braunfels, TX
    EU and rest of World calculates octane ratings different from the USA. Way up in the mountains in teh USA, the most you'll find is like 90 octane.
    In the USA, use the highest octane at that pump at that time.
    Oct 2010
    Monterey CA
    Now it was also mentioned by our chemist that "The synthetic oils are better because they flow better at low temps and because they resist tearing (shearing) at high temps. These properties are the main reason a synth oil is superior. If you were an engine, which would you prefer?" Well thats exactly why they are not so great for run in. (Unless you are in sub zero temps all the time) But even then, the fact an oil is full synthetic makes no difference to how it flows at low temps. The Viscosity rating is what matters for temp.
    Have to disagree with you on these points by our non-chemist.
    But before we go there, how many lab tests have you run with instrumentation with how many manufacturers oils?
    Jul 2004
    Brisbane
    Here we go, another thread turned into a my dogs smarter than yours.
    Unsubscribe.
    apriliaforum Member W-Dog's Avatar
    Apr 2008
    New Zealand
    unleash the dogs .....
    Quote Originally Posted by potere View Post
    My comments were generalised for the layman.
    My business is called Enviro Test. We sub contact to Lubricants NZ & Elf Oils. All we do is test shit! So I guess 35-50 week lube related per wk?
    You?
    ScottyDog
    Linkage Tester !
    In The Garage
