Results 1 to 15 of 15
Thread: How Tight?
    apriliaforum Junkie WileECoyote's Avatar
    Mar 2011
    NW Indiana
    How Tight?
    How tight is tight enough for the rear wheel nut on a Duc 996? I locked rear wheel with brake and in gear but didnt want to go crazy.
    Funny quip goes here
    apriliaforum Member mikey3773's Avatar
    Jan 2008
    Adelaide, Australia
    157nM according to the dude in the dealership.
    Put some anti- seize on there too...
    DON'T PANIC
    2012 Volvo XC60 T6
    2008 Child- Female
    2002 Ducati 998
    1999 RSV Mille
    1985 Suzuki RG250
    1983 Suzuki RG250 (racebike)
    1974 Vespa 150 Super
    2x 2004 Cats of mixed breeding
    1978 Girlfriend, Polish heritage
    May 2007
    The High Desert in Lower California
    #1 Forum Magic Missile Caster
    "Every day is a good day for pie" - jrflanne
    "Good things come to those who go the fuck out and earn it" - Mardoch
    1984 Moto Guzzi V65
    1988 Yamaha FZ750 rat bike
    Mar 2011
    NW Indiana
    Very good. So my 250 lbs of luciousness definatley will do.
    May 2007
    Quote Originally Posted by WileECoyote View Post
    Is that the problem with Valentino's race bike? They didn't use "luciousness" during preparation????????
    1984 Moto Guzzi V65
    apriliaforum expert wrx_02's Avatar
    Nov 2008
    Fort Worth Texas
    Quote Originally Posted by mikey3773 View Post
    DO NOT USE ANTI SEIZE. You wont get an accurate tq reading.
    I am working on my buddy MV right now. Rear axle is 55mm and tq to 170ftlbs. (240Nm)
    On the rear wheel it shows it is a reverse thread. Make sure which direction tightens and loosens on your bike.
    The dealer he took it to used a 300 lb impact and tried it both way.
    So now I need about 600 ft lb impact to break it loose.
    CMRA #728 Novice
    2006 GSXR 600
    http://www.scracecenter.com/
    2007 SR50 Factory:
    Malossi 70cc Kit, ECU
    Full Circle Racing Crank,
    MHR pipe, White Spring
    7g Dr Pulley Sliders
    1964 Vespa:
    133c/4spd conversion
    Mar 2011
    NW Indiana
    Yes, luciosness is what Val needs.................
    wrx, if I were closer I'd lend you that extra bit you need. I been on vaca and feel like I'm up to 265 lbs of lucious.............
    Thanks much ya'll.
    Nov 2008
    Fort Worth Texas
    Started on it and about 3 beers into it I got it to break.
    Good thing I was off the clock cause I think it was the 3rd beer that did it.
    CMRA #728 Novice
    2006 GSXR 600
    2007 SR50 Factory:
    1964 Vespa:
    Mar 2011
    NW Indiana
    Quote Originally Posted by wrx_02 View Post
    Right on, good on you. Thats about what it took me too. Be safe bro.
    Jan 2008
    Adelaide, Australia
    You can check with the manufacturer of your anti-seize for a correction factor and apply that to the torque setting if you want to be extra sure. In 20 years on cars I have never has a problem with just running the standard torque numbers on everything, anti-seize or not.
    I think they need anti-seize on that particular nut given the large size, small thread pitch and where it is on the bike.
    Got any pics of the new wheels?
    DON'T PANIC
    2012 Volvo XC60 T6
    2008 Child- Female
    2002 Ducati 998
    1999 RSV Mille
    1985 Suzuki RG250
    Mar 2011
    NW Indiana
    Mikey, this was a prep run for the new wheels and an inspection. When the wheels come in I will definately show them off. Speed said they'd be 2 weeks its been about that so any day now.
    apriliaforum newb Curveman's Avatar
    May 2012
    Michigan,U.S.A.
    !!! Always.
    Saving my pennies for a New Bike for the Stable.... for now I'll just ride the Duc.
    apriliaforum Junkie IBA270's Avatar
    Dec 2011
    Dallas, Texas
    No anti-seize, torque to spec...but first, drill your hub and install a pin.
    Trust me.
    Apr 2013
    Dallas, via Sydney
    Shortly after I bought my 10 yr old 996 I tried to remove the rear wheel for new tires and the nut was seized on the hub. The dealership said they could try to get it off but would most likely need to replace the nut, the hub and any bearings affected. I took it back home, cut the nut without damaging the threads on the hub then changed my tires. and replaced the nut/spacer.
    I'll be using anti-seize from now on.
    "The smaller the motorcycle, the more it can teach you." -Ben Bostrom
    2007 TT-R125 | 1994 RGV250 | 2002 KTM 520SMR | 1993 HONDA NL0B RC30 |2000 Ducati 996 Devilquattro | 2013 RSV4 Factory
    SV650|ZX-7R |WR426|VOR SMe |DR650|VFR800 |VFR800|VFR800 |KLR250|KTM500 |RGV250|RGV250 |RGV250|CBR600 |GSX250|ZZR250 |CT90
    %@*#&! hank's Avatar
    Earth
    The rule of thumb is torque it until the ring lock pin hole in the axle is open enough to accept the actual ring lock pin.
