Originally Posted by
Micah / AF1 Racing
SoulDaddy, you have a vacuum leak somewhere.
As far as dyno charts go I can show a few if this thread keeps alive till I get back to work. Even going from 51-57mm on a stock motor made no gains on my personal bike and actually lost a small amount of top end. What you "feel" though is totally different since we ride bikes and not dynos. The dyno numbers are basically the same no matter which set of TB's is installed because dyno tests are typically only done at 100% throttle settings. At least dyno charts that get printed out and bragged about. Why do they feel so much different. Math, simply math in the end.
The difference in mass airflow between say 0 and 5% throttle is MASSIVELY different between 51-57mm TB's. The effect is WAY more air bypass at a given small throttle setting on a larger TB set, we feel this as increased power because we are now making more power at say 10% TP than we made before at say 20% TP with the old 51mm TB's. The wide open mass air demand is determined less by TB size on the V990 than by valve size and port shape and velocity. The 51mm TB's have considerably high air velocity through the TB and down the intake ports than the same port using a set of 57mm TB's at heavy throttle settings. This results in better trapping efficiency in many cases from the smaller set of TB's.
I know it is weird math, especially from a guy with three sets of TB's for sale right now...
