Page 3 of 27 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 402
Thread: Potential custom tuning solution
  1. #31
    Aug 2009
    It is old news really. I posted Dyno charts for before/after when I installed my RapiBike O2 modulator. It is slightly more expensive, but also takes signal from the TPS (don't know if it makes a difference or if it is actually used for anything). As reported before, this mod works really well and is easy to install.
  2. #32
    Jul 2009
    AUS
    Here is the wiring diagram in do where we put it..
  3. #33
    Jul 2011
    Connecticut, USA
    Slight hijack: where can you find the manufacturer and distributors of the GPR Power Jet in the USA? Also, anyone know if Power Commander has been set up for the DD?
    "I hope you succeed, but no matter what happens, Godzilla will live."
  4. #34
    37 miles E. of ATX, TX USA.
    I have used both the PCIIIusb and PCV from the Tuono on the DD, it requires patience and being able to work without instructions. You still have to get af/r basically right via return signal resistance/voltage modification before it will really accept trims without the bikes ecu fighting the trims being applied by the PC. It is an odd duck to tune for sure.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  5. #35
    apriliaforum Junkie bgjohnston's Avatar
    May 2010
    manchester, ct
    Is the Fatduc plug and play on the Aprilias like it is on the Ducatis? Or does it have to be cut and spliced in? I may give it a go either way, but need to know what I am in for, since the bike is my daily rider to work.
  6. #36
    Plug and Play on Shiver and DD750 for sure.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  7. #37
    Jul 2011
    Connecticut, USA
    How does it affect the twitchiness in Sport Mode?
  8. #38
    This in NO WAY effects the speed of the throttles opening, just gets fueling closer to right. In theory a littler richer fueling in the transition area between closed and open throttle should smooth things out, in practice this is a RBW bike so not all variables are rider/tuner controlled.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  9. #39
    apriliaforum Member flateric's Avatar
    Jun 2011
    Seattle, WA
    Just found this product for BMW. Would it be adaptable to a Shiver or DD:
    http://www.boosterplug.com/shop/cms-21.html
    And a full explanation of different system + the effect of the product on the bike:
    http://www.boosterplug.com/shop/cms-24.html
  10. #40
    Jul 2009
    AUS
    Thank's flateric ,I like what I read.
  11. #41
    Sep 2011
    DE
    Quote Originally Posted by flateric View Post
    No, that is the classic AIT hack.
  12. #42
    Jul 2011
    Connecticut, USA
    Quote Originally Posted by DoubleDee View Post
    For those of us new on this issue, what does that mean?
  13. #43
    Sep 2011
    DE
    The resistor is put in between the Air Intake Temperature sensor and the ECU, which is said to work, but needs adjustments when the ambient temps change by a lot. In the linked version a thermistor is used, which changes its resistance depending on ambient temperature. It is one step up from simply putting in a resistor. The solution Micah is proposing puts the resistor into the O2 sensor loop and it said to work much better, maybe because it is not temperature dependent. I have not done either yet myself.
  14. #44
    apriliaforum Junkie kenzo's Avatar
    May 2010
    Belgium
    Sunday the order is placed, but unfortunately still no answer.
    anyone who has to wait longer for an answer?
    Aprilia Shiver My10
    Pazzo levers, Roads Italia carbon muflers, LV-decat, DNA filter, Matris cartridge set, RBT rear sets, Seat cover, OZ Factory wheels, 15T with 520 chain conversion, Rizoma handlebar.
    Goodie's to follow: ProBolt titanium/alu bolt and nut conversion, Samco Hose set.
    Conclusion: Making a factory Shiver
  15. #45
    apriliaforum prov-nov Torana's Avatar
    SYD, AUSTRALIA
    Hopefully this will help, I tried the ECu unleashed flashed to my ecu(they said they could do it) and they changed the map, but could never get the bike running right, and they tried 3 different modified maps on it but could never get around the errors coming up on the dash and never ran smooth. so i got my money back.
