Page 27 of 27 FirstFirst ... 17252627
Results 391 to 402 of 402
Thread: Potential custom tuning solution
  1. #391
    Dec 2012
    Brisbane, Australia
    So is a "Fat Duc" a must have? and where do us aussies get one from? Last bike had a full system and a power commander and custom map - I loved how smooth it was. It would shit me if fuelling wasnt very good, and from reading some of this thread, seems like a good mod.
  2. #392
    Mar 2009
    Roseberry Creek, Oztralia
    Talk to Dave Ward (FORZA this forum) @ http://www.motoitalia.com.au/
    Gil
  3. #393
    Dec 2012
    Brisbane, Australia
    Cheers for that. Whether its the one I look at tomorrow or some other one, I will give him a call and get one! Cant stand choppy throttle!
  4. #394
    apriliaforum Junkie DownUnderDorso's Avatar
    Jun 2009
    Brisbane, Australia
    Quote Originally Posted by GTR27 View Post
    In that case, make sure you test ride in 'T' (touring mode....), Try Sports mode for a laugh though !
    As for the Fatduc, you can also just order it online from AF1 store...
    Bike Garage:
    2009 Aprilia Dorsoduro - Mods: Akra Ti/CF cans, LV De-Cat, FatDuc, STM Slipper Clutch (w/ see thru!), Samco Hoses, 520 DID/PBR conv, RSV4-R Factory Forged Rims, Power Pures, Matris Fork Inserts, Factory Shock, Braking SK2 Superlights, ProTaper Bars on billet Tuono risers, DNA Air Filter, 'Big Mouth' Air Box, Gel Seat, Evo-Tech FE, R&G Sliders, Ballastic Battery, Ti Nuts & Bolts, Lightech Alloy Nuts & Bolts, Stompgrip, Factory Carbon F... Kompo-tech Tail fairing, Raptor Ti Supermoto Footpegs, OEM less 27kgs and counting !
    2007 CBR1000RR - Modified Track-Ho. 1000RR.NET "BIKE OF THE MONTH" Winner Feb 2014 >>> http://www.1000rr.net/forums/bike-mo...inner-tcp.html
  5. #395
    apriliaforum expert Shiv's Avatar
    Feb 2010
    Bongo
    Bu if you do that better check the postage as they used to have a minimum of $40, even for tiny things.
  6. #396
    apriliaforum Junkie donimo's Avatar
    Jun 2010
    Vancouver Island
    Quote Originally Posted by Shiv View Post
    still do. Postage can be expensive, I just wish us non-US customers had alternatives.
    there are cheaper options than the FatDuc.
    2009 Dorsoduro (current)
    2009 Shiver (too small)
    1983 Suzuki GSX400E (wish i kept her)
    2002 Yamaha BWS
  7. #397
    Aug 2011
    vancouver, wa
    I noticed that the setting on my fat duc from AF1 crept from 12 o'clock to 2 o'clock. I set it back down and will put a dot of thread lock on it when I'm sure that it's right. One question: can the fat duc from AF1 be bent readily? I need to snake it around some things to make it work on my '09 Shiver, but I'm afraid of breaking it. The connectors extend quite a bit beyond the actual resistor/dial.
    Thanks, John
  8. #398
    Jul 2011
    Chesterfield, Derbyshire. UK
    Quote Originally Posted by johnnyb88 View Post
    Thanks, John
    It's a fibreglass PCB, so quite strong, but don't try to bend it - not a good idea!
    I made my own FatDuc using the same components. The trimpot shouldn't move on it's own...
    Personally, I set the trimpot by measuring the resistance across the lambda sensor signal pins at either plug.
    That way, you can be absolutely accurate in your adjustments & re-set it to exactly where it was before.
  9. #399
    Aug 2011
    vancouver, wa
    Okay, thanks Clint. It's tough to figure out what do do with the slack once the fat duc is in line.
    John
  10. #400
    apriliaforum prov-nov nz31tm's Avatar
    May 2014
    MI, USA
    Tucco can you tell me who the connection for the fat duc was on your 09 dd?
  11. #401
    apriliaforum expert Mardoch's Avatar
    Jun 2011
    Baton Rouge, LA, USA
    Quote Originally Posted by nz31tm View Post
    If you're wanting to know where to buy one...
    http://www.af1racing.com/store/Scrip...dProduct=56000
    2011 Dorsoduro 750 - Black
    "I contend that we are both atheists. I just believe in one fewer gods than you do. When you understand why you dismiss all the other possible gods, you will understand why I dismiss yours. - Stephen F. Roberts
    Quote Originally Posted by naimchase View Post
    Motorcycles are not just fun toys. They are a catalyst for the enjoyment of life. They enhance your own, and bring something out in those around you.
    Be open to the enthusiasm of riders and non-riders. You will be well rewarded.
  12. #402
    apriliaforum prov-nov Paul666's Avatar
    Feb 2015
    Poland
    Hi! I have dorsoduro 1200 - 2010. I want to do Fat Duc at home. Which electrical scheme is correct?
    1:Name:  1.jpg
    2:Click image for larger version.
    3:Click image for larger version.
    4.Click image for larger version.
